Do I just remove the NTC or remove and bridge NTC?
Thank you.
Need a bit more help.
The Convoy M3 driver has the NTC on the spring side of the driver.
Looks the same as the earlier photos in this thread.
But I need help, what is this blue square sticky foam type stuff on the board in this below link - shot?
https://www.aliexpress.com/item/33021024834.html?spm=a2g0z.12010612.8148356.29.10443cf11Qw1Vh
@fluke, that is a thermal pad.
It is important that you keep it on there for optimal thermal performance, or even replace one that’s even better.
@fluke, that is a thermal pad. It is important that you keep it on there for optimal thermal performance, or even replace one that’s even better.
Hi thanks.
I assumed that was what it was.
I have some on order to replace it, typical de soldered the driver and the NTC was on the spring side, thermal pad thing took a battering.
9.65€ |XHP 70,2 fahrer für Convoy M3 taschenlampe|Taschenlampen| - AliExpress
That thermal pad, in itself, can't do much to cool down the boost integrated circuit, or does it?
fluke:…
That thermal pad, in itself, can’t do much to cool down the boost integrated circuit, or does it?
Please refer to this thread
Not necessary, posting detailed (macro) photos will do. Removing the blueish foamy thing, might help though. Here we go - not the best macro shots in the world, but a quick one while I have a few moment being left alone I know it’s not the M3 driver, and they actually look quite a bit different, so it’s probably useless for what you’re after. https://imgur.com/a/0cqCG4U my guess would be this one can you try to measure resistance? also, try to measure wi…
I see that a Rofis Store on Ali offers an AAA flashlight that they say is from Convoy.
It is SS and somewhat resembles the Convoy Ti prototypes, especially wrt overall shape and size. Actually looks better to me.
https://www.aliexpress.com/item/32811288894.html
Is that actually a Convoy?
I thought there were issues with the driver?
Thanks for the info. The price is much better.
Untracked link:
https://www.aliexpress.com/item/32730506517.html
Now it opens a number of questions.
- Will there be a Titanium variant?
- Diameter?
- Does it accept 10440?
- Will it be available as a host?
- What is the driver diameter?
- Will the driver be sold separately?
Untracked link:
4.59€ 55% OFF|AAA taschenlampe, EDC taschenlampe, XPE2 led innen|edc flashlight|aaa flashlighta flashlight - AliExpressNow it opens a number of questions.
- Diameter?
I don’t think so, the light is on Simon’s Convoy store for over 2,5 years, i have never seen replacement parts for that particular light, but you can always ask Simon.
Hello Simon,
Can you source a specific tint range of SST-20 95CRI LEDs?
I used FB4 (4000K) in the Clear C8+, and that gives a nice tint, if I drive the LED moderately hard (3.5A). For some applications, I would like to use a bit warmer tint, but in those cases, JB4 would be too warm for me. Could you please check, if you could source tint GD2 or GD3? That would be the ideal choice, which could give a result called ‘soft white’ with being just slightly under 3500K?
Now that you mention it…I’ve seen this light long time ago.
I wonder why Simon was dissatisfied with the driver then…
I think I can find the answer to some of this questions. But without Ti version they are not very relevant for me.
https://reddit.com/r/flashlight/comments/dn7v2m/nld_smooth_copper_s2_w18350_tube/
Kicking myself that I didn’t pick one up. That’s just gorgeous.
Hello Simon,
It is not easy to find the specified Tc BIN
Hello Simon,
… Could you please check, if you could source tint GD2 or GD3? That would be the ideal choice, which could give a result called 'soft white' with being just slightly under 3500K?
BlueSwordM was selling 3500K GA3 SST-20 emitters months ago in this thread, I got the last two. Asking him may be a good place to start.
adam7027:Hello Simon,
GC1 or GC4 could also work for me if you cannot find GD2 and GD3.
For me, it is better to get emitters from China than US/Canada - but I will take a look there as well.
Seems to be back in stock:
Light: Page Not Found - Aliexpress.com
18350 tube: Page Not Found - Aliexpress.com
Oh god my wallet nooooooooooo
