So I just received mine and put a 30Q in it. I got the sst20 4000k version. Is the 30Q a bit too high current for this version? I have not noticed any issues but can’t see any specific warnings about using high current cells.
Should be fine. 30Q peaks at 20A, settles at about 15A, thats max 5A pr. emitter. The SST-20’s can handle currents above 6A, so no worrys
The driver will throttle down due to heat, waaay before the emitters takes any damage
Can anyone measure the inside diameter of the Fireflies PL47 gen II tube? What 21700 batteries are you using? I bought 2 Shockli IMR Purple 4550mah, and they are somewhat thicker than normal, 21.5mm or so. Will they serve for the PL47 GEN 2?
Yep, having the same problem with my 26650 Shockli batteries, they want come out my Haikelite SC04…
I don’t have a gen II, but my gen I measures 22.2mm(I assume gen II has still the same batterie tube)
Thanks for your reply. Well, if the tube measures 22.2mm there would be no problem to use my 21700 Shockli. Good news.
By the way, I also have 26650 of Shockli, IMR 5500mah, and they fit without problems in my Haikelite SC01 and SC02.
Next week I hope to receive the PL47 Gen 2 and I will tell if there are problems or not with the 21700 of Shockli.
I just put a Shockli 4550mah 21700 in, and it fits fine. A bit snug but not tight. Also a Liitokala 4000mah 21700 fits too.
Miguel_79:Can anyone measure the inside diameter of the Fireflies PL47 gen II tube? What 21700 batteries are you using? I bought 2 Shockli IMR Purple 4550mah, and they are somewhat thicker than normal, 21.5mm or so. Will they serve for the PL47 GEN 2?
Perfect! Thank you very much for the information. I hope my PL47 Gen II arrives soon
i42dk:Can’t wait to get mine :heart_eyes:
What version/revision of Anduril is used in the GEN2 version ?
And will it also have flashing vias as GEN1 had?
Firmware can be flashed using a right key-pin , just like GEN1.
I red somewhere that flashing the Gen I was only possible when the aux leds were disconnected.
Is that also with the Gen II?
i already recieve now.
confuse a ramping mode .when i press 1 click. its high level. but i press to level down and press to off.
when i click again. its jump to high level again. not remember last level.
What am I supposed to do?
Looks like it is on manual memory mode.
When light is on, press 5H(4 clicks and hold the 5th).That should solve your problem
delete:i already recieve now.
What am I supposed to do?Looks like it is on manual memory mode.
its works. thank you sir.
My PL47 Gen 2 arrived this Monday, and the truth is that I am very happy with it, here you can see some photos:
@Miguel_79:Are those nichia’s?Very nice color temp…
Looks like SST20 4000K to me. Or it could be camera trickery
Overload:@Miguel_79:Are those nichia’s?Very nice color temp…
My E07 with sst 4000k isn’t that warm
They are SST20 4000K 95CRI, I liked them in the MF01S and I repeated in this one.
Oh woah!
The anodizing is so much thicker on the PL47 V2.
Way more than the Gen 1, about the same as on the FF E07.
Loved the shared picture Miguel_79, using shockli 4550mah is a perfect combination… it look a very tight fit, but it fit…
mine still waiting to shipped, yeah maybe around 3 weeks to arrived…
My one is stuck from 04.10. in Luxembourg
After cancel order from BG, yesterday I’ve already place an order direct from their website, FIREFLIES PL47G2 CRI95 4000K SST20
