Test/review of Fujitsu AAA HR-4UTI 750mAh (Blue)
Official specifications:
  • Typical capacity: 800mAh
  • Minimum capacity: 750mAh
  • Nominal voltage: 1.2V
  • Fast charge current: 750mA
  • Internal impedance: 40mOhm at 1kHz
  • Weight: 11g
  • Low self discharge.
  • Ambient temperature: Fast charge: 0°C ~ 40°C, Discharge: 0°C ~ 50°C, Storage <90 days: –20°C ~ 40°C, Storage < 1 year: –20°C ~ 30°C
Maximum temperature raise at different discharge currents: 1A:+2,7°C, 2A:+6,3°C, 3A:+9,9°C, 5A:+14,7°C
Fujitsu has multiple series of AAA NiMH batteries, here it is the blue version.
I ordered two batteries, but the shop was obvious out of two-packs.
The two cells tracks nicely and capacity drops a bit with load, the 5A test was above the cells abilities.
Conclusion
Looks like good AAA batteries.
Notes and links
Compare to other AA/AAA batteries: Alkaline/NiMH/Lithium
Thanks for the review HKJ!
Did the package say something about the cycle life?
Look at the photos, I did not get a package. I found a datasheet, but it did not list anything about cycles.
Got it, thanks HKJ.
I could only see some plastic... so it wasn't clear to me if there was a package inside :)
Thanks HKJ!
Are they LSD?
The Blue AAAs seem to have only 60% life cycle compared to White AAAs
The Blue AAs seem to have 70% of cycle life compared to the White AAs
Cheers,
AA Cycler
I did write Low Self Discharge in the review, but I could not find any specifications what they mean by that.
