Be aware that 60W panel has no direct USB output and this picture is misleading.
You would need an adapter to connect MC4 cables with the USB output.
Doh! Thank you, that’s troublesome although I’m going to hook it directly to a Lipo battery backup with MC4 cable connections so I should be good? Do you happen to have a link to an adapter that would work?
Couldn’t find one tbh and was seriously considering making an adapter by myself from parts:
1FT 2.5mm2 MC4 Connector and DC Power Cable 5.5mm x 2.1mm Female Jack
Fortunately Banggood sent missing adapter (just after 3 chats with their customer service)
Whoa when did they release the sand color FW3A?
release just getting ready )))
ATTENTION!
Procedure for using coupons has been changed!
1. Select the product(s) and put it in the cart.
2. Go to the cart and click "Proceed to Checkout":
3. Select the checkbox "Clip coupons" at the bottom of the page:
4. Enter the coupon code, click "Apply" and check the discount:
5. Go to the payment process
Hi Fin,
Code for Lumintop EDC18 does not work for me. Updates?
Thanks!
Keepitsharp
Coupon will work after the end of promosale
coupon for Xiaomi 2C 20000mAh don´t work.
Looks like the lowest price ever for Wiha. But I spent too much recently…
It’s really nice. It’s also quite useful unlike having another light that you don’t need. I can recommend this product.
Yes, Wiha products are good!
Maybe I ask for coupons for other Wiha products?
XIAOMI MIJIA Wiha 8 In 1 Ratchet Screwdriver
XIAOMI Mijia Wiha 26 In 1 Multi-purpose Screwdriver Set
Wiha Zu Hause Electric Power Screwdriver
Wiha 17 in 1 Daily Use Screwdriver Set
Wiha Zu Hause 20V 200NM Cordless Electric Screw Driver
Wiha Zu Hause 20V Cordless Dual Speed Electric Drill Driver
Wiha 6inch Needle Pliers High-carbon Steel
Wiha Hex Wrench 9 Piece Set Crocodile Screwdriver Kit
I’m certainly not in need of anything these days, but I also enjoy seeing good non flashlight deals.
