Oh! Wellp, nevermind really. Found this Shop2097037 with slightly better pricing, interesting cells and cell packs.
They're selling this weird LiitoKala branded li-ion 7200mAh :???: 26800 cells with tabs, guess that is some electric vehicle market product (5C discharge rating). And I must also say, without a doubt, that 7200mAh in a 26800 is high energy density, beating PLB 5500mAh at least on paper.
Henrink, did you ever tested some electronic load like the following? (guess the answer is not yet)
Had a different, more display fancy electronic load in my wishlist but people were reporting failure to disconnect load after voltage cut-off in it. This one has good reports, guess I would only need a battery holder to complement with it.
I got and tested the Varicore batteries some time ago.
I started on in once, but it died on me. The problem is when they use a single mosfet transistor, standard mosfets are not good at analog regulation and cannot handle anything like the rated power when doing that.
That cell is a problem, it will not fit in my battery holders, 70mm long is about maximum I can test.
I bought some aaa batteries from ebay. The picture showed contour batteries. I think this is a good company which closed down or something…when they arrived they were Digimax. I discharged then charged them at 200mA in an Accupower IQ328 and two of them kept fluctuating between 1.41v and 1.42v. I ended up stopping the charge after 5 and a half hours! I know the current should be at least 0.3C but I wasn’t expecting this from brand new batteries. I always select the lowest current for new cells and when condition cells.
The balance board does not balance the cells, but that is no problem because charging and balancing the battery pack after taking it off the wall took only 4 minutes and 2 seconds
(The cells were charged and balanced before capacity test.)
If there would have been a large difference between the two cells, the charge/balancing time would have taken much longer than 4 minutes.
These cells are much better than the Original lead-acid battery that became useless after about one year.
A new 6V/4A lead acid battery is also more expensive than these cells + the protection board.
The LiFePo4 cells are still like new, it looks like they will last many years in that solar powered light.
I like the tests of new cells, but i am also interested in re-tests after they have been used in “real life conditions”.
I know it is very difficult to do that, but in this case i will continue testing these cells once a year
In my experience balance boards are designed to start resistor draining the cells at some overvoltage (overcharge) point. This, in my opinion, is a simple but effectively useless approach as overvoltage hastens cell damage (you want your cells to live long, not to die soon).
To keep cells in balance manually I would install voltmeters and pushbutton enabled bleeding resistors at each battery stage.
I've seen such top before (BAK 18650-34T), take a look right here. Not a bad cell, but I prefer not feeding bad business models. You can buy BAK 34T cells with a lot less misleading wrapper. For example:
Hello HKJ, I suggest you the test of a new cell in format 18500 that I discovered recently and which offers better capacities than those proposed by Sanyo, Panasonic or even more recently the rewrapper “Vapcell”. It is a cell manufactured by YLE (YikLikEnergy) in the format 18500 with a nominal capacity of 2250mAh (and it is not exaggerated!) For a continuous maximum discharge announced at 4 Amps, to see if in reality we can not push to 5A see more … They are sold in pairs what will arrange you I think for a test, here is the link to buy a pair (box provided):
Personally, i have tested the YLE 18500 2250mAh, their announced capacities are reals but according to the returns I had on “YCDC 18500 2500mAh” they would be 18500 2000mAh with the exaggerated capacity, incidentally there is no official datasheet for “YCDC” while the ” YLE 18500 2250mAh “have an official datasheet as you can see in my post. And yet I’m not a big fan of Chinese manufacturing cells, but this one from YLE are really excellent I must admit, even Panasonic does not do as well.
