I don’t think I’ve seen mention of this type of metric before.
I don’t think it would have much impact on wall-outlet based charging as the only different would be a little time. Charging from a limited supply like a solar cell though, I can see where you might want to know which cells will use the least source current to achieve a full charge.
I also don’t think this is an actual, distinct mode. What you’re asking for is just an additional calculation based on a standard Full Test. I see the biggest challenge being finding space on the display to show it.
Yea I thought it up.
For the flashlight community, you are right, efficiency is just a matter of a little more time on the charger. But for the DIY Powerwall community, battery efficiency would be very interesting and could identify poor performers.
Would be interesting. How about real internal resistance measurement? How about tolerance for finish charging/discharging voltage? Especially I prefer finish voltage less than 4.2V, better 4.19 minus .05V .
I like the display of the XTAR VC4S. It shows all information for all channels at the same time.
I also want two USB outputs for loading i-phone etc.
This reduces further power supply units.
Here are the additions since last week’s update and the BLF INTEREST LIST file linked to in post #1 have been updated too.
The interest list count now stands at 404 chargers.
POST # NAME
915 Tete
917 micknatt
918 Lipfit2000
919 mavortium
920 brenden23
921 ISO
922 iamnuts
923 4141003
924 scarnific
925 P33
926 Marc E
927 alex64
928 Kiltan
929 redsuns
931 LOTL
932 bmansc
933 Flying Luminosity
938 borealis
942 Muto
943 der_horst
944 opbigdave
945 netgear68
946 patchythepirate
947 Petr Sixta
948 dnei519blf
949 mkor100
950 t-soung
One qestion, maybe it came up already, but I only see low voltage recovery for li-ion.
It is one of the things I dislike on the opus, when trying to recharge fully depleted NIMH I always need to “jump start” them in order to get recognised.
Will this problem be solved on the BLF charger? That alone is a good reason for purchase!
@ BlueswordM What is the reason not to be able to recover NIMH? Quite a few of my AAA’s are down to 0 when I recharge them. Even eneloops that have been charged once. They seem to work 100% after the recharge.
Would be a very nice addition IMHO!
For the 9V’s in my sons RC car remote I can live with These
I’ve been using NiMH AA and AAA batteries for decades, but I’ve never discharged any to 0V, so that’s pretty impressive . Perhaps…
1. Features on this charger are frozen, or at least gelled .
2. Recovery is actually somewhat difficult as it’s the battery chemistry is not obvious when the voltage is out of the normal range. Triggering a recovery mode manually would be desirable, but adds complexity to the user interface (I would like this option, as it avoids auto-detection and requires special knowledge).
I’ve occasionally had to recover NiMH cells, but it’s usually as simple as shorting the positive and negative terminals with a cell inserted. That tends to jump-start the charging process on my old LaCrosse charger BC-700, anyway.
