Interested.
Hi freeme,
Can I have the code, please?Thanks
Interested
In! Thanks!
freeme,
order placed thaks
Thank you.
interested
Vendor has started shipping K3.
Can i have the code too?
Sent.
Hello freeme, thanks for the code. Already placed my order.
Just received my K3 Lite Damn, its tiny XP-E2 red LED out-throw bicycle tail light!
Hello,
just received the light today. Is it normal that the UV light is greenish instead of purple?
Although my 365nm UV light does produce similar yellowish-green tint hotspot too, this is my first encounter for UV light with such tint.
Green tint is usually regarded as bad output for white LEDs, but i was surprised that K3 UV was able to illuminate embedded fibres and UV-fluorescent phosphors ink well across the entire length of the note. I also find green tint/ cast was more forgiving to my eyes, when i was inspecting the my other currencies.
Both photos are taken with same exposure duration, with beam direction from around 11 o'clock.
Interested.
Is too late for me??
The Green in the UV is weird, but it still seems to work.
A couple of things I didn’t notice in the now discarded instruction manual:
- As noted in the manual, the light remembers what color you were on BUT you can force it to white light from OFF with a long press. Nice touch.
- 4 clicks or more will lock out the light. To unlock click 4 or more and then hold down the switch til the light comes on.
- Clicking within a couple seconds from turning it on allows you to step through the output, MLH, but if you’ve left it on for more than 5 seconds or so it thankfully just turns off when you click.
This is a solid little 5th pocket light. Yes there are better lights out there but if you need white light +UV or RED, and tiny size this isn’t a bad choice.
Also the triple click from off for battery voltage is nice.
Please me coupon
Red is quite bright. I wish there were a low mode instead of SOS. A beacon would have been nice, too.
Sent. [quote=aors10] Please me coupon [/quote]
Agree. I wish Fitorch keeps improving K3 or their future keychain lights.
