Indeed, it looks promising. Any pricing info?
This should be promising. It’s a great LED choice for sure.
Looks good, quite like the blue ring. Good emitter option, will be curious if the UI ticks the boxes.
OP updated ;-) I have no detailed prices yet but I will inform about it a.s.a.p..
I will supplement information on the UI later on.
I love my WK30 so I might have to pick one of these up. That emitter is amazing!
I would love to see Wurkos come out with a small (as small as possible) 18350 light with the LH351D emitter and smooth ramping. I’d be happy with a TIR optic to keep the size down but a reflector version would be cool too.
Looks like it might share some Sofirn genes. Specifically the SC31B.
It certainly shares one thing. The mediocre clip that is on hundreds of other lights
In for one!
It looks like SC31B head with ED01/Worm ribbed body.
I hope they tweaked the UI to have faster ramping and a lower low. I never use it on the SP32 because Anduril/Narsil does it better.
Looks good. Waiting for more UI info
UI and ANSI specs supplemented.
Why designers choose “hold for off, click to cycle modes” instead of the reverse is… puzzling.
It’s like people without legs designed a bicycle for people without hands.
Technically it works, but it’s awkward and non-intuitive.
I think it might be to prevent returns from users used to lights having a single mode - not that it justifies it, just my theory.
I prefer clicking to change modes, unless in ramping mode - then I control how fast the modes change and always stop on the desired mode.
With hold to change modes, as on my Rofis R1 and R2, I sometimes have to go through the cycle a couple times to stop on the correct mode.
I do like click for off, but you can’t have click for off and click to change modes in the same single switch light.
Oh boy. I’m excited about this light.
Please tell me this is roughly the same reflector as the WK30.
I call that the “Acme Clip”
I haven’t used any Rofis lights but no light with hold-for-cycle I’ve used has been anywhere close to fast enough to overshoot what I want. I do like how fast you can cycle them with rapid taps on tail-switch lights and the dual-switch TO50R I have though.
My thoughts…
The Good:
- Great LED choice
- USB-C charging? Awesome
- Shortcut to turbo (will this work from Off?)
- Ramping option with single click on/off
- Below $30 including a battery
The Bad:
- No mention of Eco/moonlight shortcut (hold from Off would be good)
- Hold-for-off in the stepped mode
- Timed stepdown instead of temperature regulation: given the price point, I can forgive this. But it does make me a bit sad
looks great, looking forward to it .
