Exactly.
It can definitely be tricky to make a single program work consistently on a variety of different hardware. It involves all sorts of different abstraction layers and modular designs to allow the front end to remain pretty much the same regardless of what back end it’s running on.
Which is why FSM is such an amazing beast.
Hank said the head is 70mm which means it should be over 600kcd
Edit: It’s 550+
Edit: It’s 600+ now so I guess I was right
Any news on when it will be released?
Soon™
Interested.
Interested.
Interested!
Sign me up for 1 :-p
(interested)
Hank if you see this thread we would love an update on this project
Yes, we are still working on it, here is the prototype photo, it’s not called D1SV2, it’s called Noctigon K1,
with fully regulated driver, it should reach 600+kcd with CSLNM1.TG LED, there will be green/red
beam version, as well as XP-L HI/HD LED with different color temperature.
Beautiful!
This looks like it will be a killer light!
What battery does it take?
21700 with the 2A type-C charging port on the threads.
contactcr:What battery does it take?
Both are excellent choices, thanks.
Now I just hope you test an aspheric lens/bezel for it like I emailed about. Maybe asking too much
Looking great! And it you cover the reflector part it looks like a regular D4
JordanZHP:Hank if you see this thread we would love an update on this project
Hank that looks amazing!
Are there different tint options for the CSLNM1.TG LED or only CW?
Thank you for the update.
WOW!!
CSLNM1.TG is only available in cool white, around 6100K typical.
