Latest release Vapcell 21700 5600mah 12.5A battery
Are those suitable for flashlights?
I often see these claims in battery advertisements, and sorry to say but that is wrong. Batteries can be used to power up a multitude of things. I could use a battery to power up a personal vibrator, for example.
The pertaining question here is, ¿is the flashlight and its driver designed to make use of such battery? Also, ¿is the flashlight user knowledgeable and responsible enough to properly take care of it?
I am not aware of flashlights designed to be powered by 26650 LiFePO4 cells. This could be useful for very low Vf leds and linear or unregulated drivers.
After the very good experience with the Vapcell support during my last order i ordered the 18350 cells now. DHL did not leaf a message that the package is ready for pickup in the Post office 150m away.
So the package was send back. Instead of asking me for money (thats what AE usually does) the Vapcell Support contacted DHL and managed a second delivery for free. 1A Support and fast help.
And not only the support is great i can only say good things about the cells. Untill the next buy.
I’d like to check out the Vapcell S4 Plus charger, but going to the AliExpress link, it indicates “cannot ship to my country”…
Why not LiFePO4?
Like above here's the link “international/english version” fixed: https://www.aliexpress.com/item/4000249374391.html
Vapcell
When you add new info to this post please add a new post to the end of the thread at the same time as you modify the first post that way people will know what was changed and get a proper notification
Thank you very much. We will improve
Well, do many people use IFR batteries If there are many demands, we will upgrade the other version, plus the IFR battery and 4.35v battery
By the way ,vapcell U2 can charge IFR battery :smiley:
Can we say word or two about this in AliExpress Vapcell Store? Is it “real”?
Description: Vapcell original mini lithium 3.7V battery INR 14500 1000mah 10A rechargeable battery for flashlight / power tools
Url: https://www.aliexpress.com/item/4000594740211.html?spm=2114.12010612.8148356.19.44d01edcalyI26 (AliExpress Vapcell Store)
…and as “proof” in description at aliexpress used this graph of completely different batteries (Vapcell ICR14500 1000mAh (Gold) 2018) rated by HKJ:
The Vapcell store is original. The cell is a new one, not yet tested. If it’s really 1000 mAh 10A - WOW, a real upgrade over what we’ve seen so far.
I agree that it’s dishonest to show a test of a different cell.
Dennis updated the OP with this 10A 14500 cell, great development! , it goes with a different chart which is probably correct. So have a look at the first post. Also a very interesting: a 2200 mAh 18500 cell that does 4A.
I think Samsung 18500 can do 5A if i’m not mistaken
1000mAh and 10A is awesome if true !
First of all, chances of it not meeting its capacity rating are very high if not guaranteed. And we'll see what happens with the maximum continuous discharge rating, it is doable but if also a little bit exaggerated the 10 A curve will look flat/deflated (low voltage). But well, wow.
Suffice to say I am quite fed up with marketing lies, particularly in the battery industry.
Edit. Forgot to say before, but djozz remembered me: it's not really dishonest to show a perfectly identified test of a different cell, it's just plain stupid.
Fri, 01/10/2020 - 16:35
Strangely, Vapcell has two listings for this cell on AE. One references this incorrect graph, and the other one doesn’t. Price is different as well.
I’m not sure that Vapcell is deliberately lying about their batteries, sounds more like clumpsiness that they publish a wrong chart, that shows less performance actually than what the battery in question can do, not a very profitable lie :slight_smile:
We'll see once it gets in the way of HKJ's or Mooch's steamroller.
Yup. My guess is they used the old listing for their ICR14500 cells as a template, and didn’t clean it up properly.
Yup, let’s wait and see.
FWIW, I only have two of their cells (16340), and based on what my Lii-500 reports, their capacity is notably lower than what Vapcell claims.
So far Vapcell had a good feedback. Let’s see what HKJ and Mooch will say
