✌ FREEME - ASTROLUX MF01S 15000lm Flashlight Group Buy - ENDED
https://www.1thedeals.com/product/astrolux-mf01s-18sst20-xp-g3-15000lm-cri95-418650-flashlight-with-4samsung-30q/
Should FDIFF coupon still work for the diffuser?
Yes, but you need to spend at least USD30 to entitle for free shipping.
I tried to buy one with a set of 30Qs button top,but they ask $129.95,so I turned back.
Did you put in the discount code?
I can’t combine the coupon option, with the combo light+batteries purchase. :frowning:
Our deals is still ON. PM me if you still having problem.
I can choose free shipping for the order but I can not use the coupon at the moment because of the promo tag.
“Coupons can not be used on the products labeled with the “PROMO” or “VIP” tag.”
Looks great! It always bugs me if the anodizing doesn’t match on the different pieces.
I don’t know if it would work on Greased Lightning (being a degreaser, I doubt it), but when I strip anodizing with lye (drain cleaner), I coat any areas I don’t want stripped with Vaseline. Works great.
Question, which one of the seven ramping modes is regulated. somebody said that about 600 lumens is regulated but which mode? Thanks
I have not heard the particular mode, someone will probably need to try the different levels and look for pwm through a fan or something.
Can it really be called regulated? It’s a twin FET driver with the small FET running at 100% so you don’t see any PWM effects. I don’t really know.
Anyway, I’ll ask the person who does know.
Hi thanks I don´t know that is why I am asking. I read somewhere that there is regulation in lower mode about 600 lumens, something like emisar d4s and that emisar d18 has regulation in higher mode I think it was between 1000-2000 lumens in case of d18.
Toykeeper says it’s step 4 of 7 steps, about 500 lumen. You should see no PWM effects on this level.
I don’t think it can be considered regulated, though. The power is reduced by going through a resistor bank as opposed to going through linear regulators. This is due to it being 6v nominal and 7135 regulators don’t always behave at such high voltages (8.4v).
The D4S and D18 are both 3v nominal, well within the range of the 7135 chips.
Hi Freeme
I am Interested in a MF01S 15000lm
(with the 30Qs batteries included)
same as the Theodore41’s post above,
the page charges full price (with the code entered)
I would also like a holster
also may be interested in the mf01 mini 7 sst20 5500lm
w/ 26650 battery shown on your page
(code not working for it)
also a holster -
All ramped levels show PWM. It’s only visible when facing the light at the camera at a close distance. The frequency is high so it doesn’t flash but you see some lines.
Just used this promo code and it worked! Thanks Freeme for the deal! Can’t wait for it to get here!
I finally could purchase one, and today I received it.I now charge the batteries by a Nitecore charger at 2A,waiting to be finished,so as to see the beam and take some measurements.
I could say that turning it up while batteries were at 3.36V,the light which I saw on the ceiling,as it is daytime now here,is less than the modded by the BLFer giorgoskok, Astrolux MF01,which has a throw of some 85,000cd.
It is the throw I want to see as well ,after the charging is finished,and take some measurements on a Dr. meter luxmeter.
After finishing charging,I see that it is stronger than the older one,but I have to make the mesurements to see the throw.Anyway,trying to lock out the light,I see that while being locked out,it is blinking both,the green switch light plus the coloured leds inside.
Is it normal?
I have just taken a measure with a luxmeter,and I found that it is 105.900cd.Not bad,not bad at all…
Urgently need advice. Which batteries are best used for a flashlight. It is necessary that it burns as long as possible at maximum power.
