SBT90.2 In BLF GT
38 posts / 0 new
Wrathbringer27
Wrathbringer27's picture
Last seen: 7 hours 12 min ago
SBT90.2 In BLF GT
I’ve seen beamshots from M4DM4X. Thinking if they will sell conversion kits for current stock GTs. Throw numbers we’re at 2.65km and 6k lm iirc.
Edit: is it good enough to just get the led and swap it?
Words can be broken,
so can bones.
Edited by: Wrathbringer27 on 10/21/2019 - 19:37
Rayoui
Rayoui's picture
Last seen: 1 hour 44 min ago
I don’t believe so. The XHP35 is a 12v part; the SBT90 Gen 2 is 3.5v.
The_Driver
The_Driver's picture
Last seen: 12 hours 53 min ago
You just need a different buck driver from Lexel.
Glenn7
Last seen: 1 day 16 hours ago
I think if they made an SBT90 gen2 driver and led kit for the GT, mugs like me would do the “shut up and take my $$” thing.
Wrathbringer27
Yes I want that too
so can bones.
grin
Last seen: 2 hours 39 min ago
Driver is the next hurdle i will do some current tests on the k75 soon
Tom E
Tom E's picture
Last seen: 5 days 8 hours ago
Dunno if any buck driver can go that high in amps. Best thing would be modding the battery carriers for 4P.
grin
You can make 4p battery holders from 2 astrolux battery carriers with no modification
Tom E
Tom E's picture
Huh? Ok, you got my interest. Do u mean the astrolux carriers would fit in a GT?
Tom E
Tom E's picture
In case anyone is look'n for it, if not already posted, Wendy emailed the SBT90.2 datasheet to me, I posted it here: SBT90.2.
Lexel
Lexel's picture
Last seen: 25 min 58 sec ago
If Lumintop would be interested I would finalize my very high current driver for 3V LED from 2S battery
The head part would be needed to machine out proper parts for thermal pads to get an efficient cooling, but even without that it might be enough to get rid of about 4-5W heat
Tom E
Tom E's picture
Ah, but the GT is 4S. Would it work for 4S?
FlashPilot
FlashPilot's picture
Last seen: 8 hours 18 min ago
Ive been waiting for someone to approach this. Subscribed!
Yokiamy
Yokiamy's picture
Last seen: 16 hours 51 min ago
Lexel wrote:
If Lumintop would be interested I would finalize my very high current driver for 3V LED from 2S battery The head part would be needed to machine out proper parts for thermal pads to get an efficient cooling, but even without that it might be enough to get rid of about 4-5W heat
Sounds too difficult for entry level modders, most people just want a conversion kit (as with the XHP70) driver, mcpcb with LED and different battery carriers for 4P.
Nobody is waiting to machine his GT.
grin
Im not sure the astrolux carriers are 2s2p. At work at the moment when i get home i will measure them
grin
I would be interested in testing them for you in custom made lights with sbt-90 and a cft-90 using GT reflectors i have
Yokiamy
Yokiamy's picture
It seems the Astrolux carriers are 2S 2P, so you have to mod them
Lexel
Lexel's picture
There is no modding if Lumintop would release a SBT GT
4S would need a way bigger inductor size than 2S or current had to go down a lot
At a current like 35A you cant make an easy mod, I bet also the K75 has dedicated heat pads to cool components on the driver
Things get toasty at that high currents even with 95% efficiency
grin
I would mount the driver i something similar to this. Tonight i will take my K75 apart to see how it is done.
2 astrolux 2p2s battery carriers can be made into 1 4p carrier with no modification to the boards.
Redlyne22
Redlyne22's picture
Last seen: 20 hours 59 min ago
Grin, taking the k75 apart would be much appreciated. Really, Looking forward to it.
And also, which driver is that in your pic, looks super familiar.
Sometimes being a newb is the best part of a hobbie
Hoop
Hoop's picture
Last seen: 2 days 16 hours ago
Taskled H6Flex.
grin
Hoop wrote:
Taskled H6Flex.
Tom E
Tom E's picture
My 3 ordered SBT90.2's arrived today. I got a couple spare GT's to play with. The LED's are a big assembly - no idea how I'll fit them in a reflector. Might be better off in a zoomie for now. I got a couple big zoomies - the 1504. Betta it would be interesting in one of these...
grin
Tom E wrote:
My 3 ordered SBT90.2’s arrived today. I got a couple spare GT’s to play with. The LED’s are a big assembly – no idea how I’ll fit them in a reflector. Might be better off in a zoomie for now. I got a couple big zoomies – the 1504. Betta it would be interesting in one of these…
I did dismantled my K75 and soldered some cables between the driver and led to measure current. Results
Low 500ma
Mid low 800ma
Mid high 2.7A
High 5.9A
Turbo 28.7A
How do you plan to driver them and at what current? I have some GT reflectors for scratch builds, a massive triple with 3 GT reflectors would be fun but the power needed would be huge. I have 6 on order and im going to need drivers.
Tom E
Tom E's picture
Straight FET or FET+1. Doesn't need anything special. Even the SIR800DP can handle the amps, but I have better FETs. If the K75 can do 28 amps, should be able to match it, or little better perhaps.
That's pretty good #'s. The 1504 unfortunately is designed for a 16 mm MCPCB - forgot bout that, but looks like I could dremel it out to about 19 mm, so might do that. The other high performance zoomie is the Brinyte B158 - I got one with an empty spare brass pill, and that's for a 20 mm MCPCB.
Still a good deal here: https://www.aliexpress.com/item/32831194642.html?spm=a2g0s.12269583.0.0.7e7414fey5MN4W
grin
Cheers I am getting my head around how to drive them, it should be simple enough. I ordered mine on 45mm mcpcb.
Funtastic
Funtastic's picture
Last seen: 4 hours 12 min ago
This sounds very interesting
Texas Ace Lumen Tube calibrated with maukka lights
Rob1563
Last seen: 2 days 10 hours ago
Also interested in a beginner mod type option
X70, Blf GT, FT03(xhp50.2), TM16, Emisar family, and many more
Tom E
Tom E's picture
I finished the 1540 mod, details here: http://budgetlightforum.com/comment/1590861#comment-1590861. Not getting the amps I was hoping for, but it's not fully tweaked for high amps - should use a better FET, thicker wires, etc.
Nicolaas
Last seen: 2 days 12 hours ago
SBT 90.2 conversion kits for BLF GT would be fantastic, this would be THE led for this light.
FlashPilot
Id imagine its not “if” but “when” it happens. And when it does, sign me up! As tempting as it was, I just couldn’t bring myself to swap for the XHP70 kit and lose out on the downrange concentrated illumination and efficiency the XHP35 provides. I have plenty of large flooders to fill the gap and dont need another. With the SBT90.2 in the GT, there should be no compromise and hopefully greater range with the same useable spill the XHP35 already provides. 8 × 18650’s should provide the perfect economical solution to minimize voltage sag while allowing the host to heat itself to some nice hand warming temps!
The awesome specs for the chunky GT host speaks for itself and is practically screaming for this upgrade. As always, patience is a virtue…
