Osram Oslon Boost HX
Is there an expected delivery date on these?
Fun fact:
Osram specs the height of White Flat (both 1 and 2 mm²) as 0.73+–0.07mm.
Boost HX is 0.732+–0.035mm. Halved tolerance?
It's been a year, Osram seems to be really taking its time with this LED.
No, a different trainee wrote the datasheet :)
Another distributor lists Boost HX on their site…MOQ is 4000 and they have no stock.
https://www.ttiinc.com/content/ttiinc/en/apps/part-detail.html?partsNumber=KW%20CULPM1.TG-Z6RF7-E&mfgShortname=OSR
LED4Power has them in single quantities.
Probably for about five minutes after this comment goes live. I’m half tempted to buy one, but I’d put it in my C8, take some pictures, hate the backscatter from the high CCT, and put the SST-20 back in.
These are Boost HL, not Boost HX. 1mm² die instead of 2mm². Better throw but only marginally for not much more than half output.
Ahh, so it is. I didn’t notice the P vs N in the part number.
Now Vinh has them as well:
https://www.candlepowerforums.com/vb/showthread.php?454513-The-Lounge-2019&p=5352694#post5352694
Ah! So they actually exist now. :smiley:
We need that :+1:
I think Led4Power has them, but his shop is closed until next year iirc
L4P had the Oslon Boost HL notnthe Boost HX.
I’m aware. I believe he has the HX now, after his store closed this year, based on the fact he offered it as a prize in the Old Lumens contest
Is the boost HX just a 4040 version of CSLPM1.TG?
Aka culpm1.tg
Yes. But considering that thermals seriously limit KW CSLPM1.TG - this is likely a significant upgrade.”
Anyone know where to get them? Im aware the cslnm1 and cslpm1 cant take direct drive but anyone think this one will?
Probably still a bad idea.
I think I read somwhere that Vihn has not been able to get the angry blue tint shift with this led? I might be wrong. I’ll try to remember where is saw this.
Linked to a CPF thread recently…
Anyway, strap one to a 30T and I doubt you’ll like it.
That still doesn’t mean direct driving it is a good idea.
It will mainly produce more heat at some point, which is bad for run time and life time of the LED, and cooling can become an issue.
And it’s not as if there aren’t any good FET constant current drivers available.
Convoy has the SST-40 drivers, one does 5000mA and the other does 6000mA, and you can play with the sense resistors if that’s not ideal.
Tests of the Boost HX will determine what’s the best maximum current.
