Good to know. I just purchased three units. If you can confirm turbo is in the mode sequence or at least if turbo can be memorized, I’ll purchase another 3 or more more.
How’s does the SBT90 Gen2 compare to Osram leds, such as white 1mm, 2mm etc?
SBT90.2 has wayyy more lumens, wayyy more amps. Not sure head-to-head on throw in similar lights, but I would imagine the 1mm/2mm's are more of a pencil beam simply because of the higher lumens of the SBT90.2.
I try to find out
Edit: Neal said yes
Placed my order, thanks Martin and Neal.
Yes to what? Turbo can be memorized??
correct
Wonderful. This light is gonna be a hit.
For the price with a SBT90.2 it surely will
Wonder what the flux bin is. Here is the chart from the SBT90.2 datasheet below. I'm trying to order 3 pieces of just the LED mounted on a 20mm MCPCB but all they had was flux bins RB and SA, so I'm ordering the SA bins, but there 5 higher bins listed:
The last bin is crazy! Wonder which one is being used in this light. Btw where did u even find this datasheet…Mars? Pluto?
I asked Wendy and she emailed it to me -- will post a link to it on my google drive share...
try this for the SBT90.2 datasheet. let me know if it works or not for you.
Agree - would be great to know the bin they are using in this light.
I wonder if there’s any chance for a group buy to get the top bins. Perhaps we can chip in with some light manufacturers or sellers like KD, L4P, MTN, Emisar.
I'm think'n the higher bins might not exist yet. CREE would do the same thing - all bins/tints listed would no be available, but for CREE now, they are mostly at the high end of the bin range anyways, sometimes higher than the datasheets define. It's all a matter of what they can produce, and what the distributors/resellers carry. Maybe the high bins exist but are twice the price - who knows...
Thanks a lot for that datasheet!
Some notes:
- this LED has seriously low Vf. About 3.35V at 20A.
- ~100 lm/W at 9A (the binning current), but cold binned.
- About 5300 lm at 22.5A compared to CFT-90 4800 lm (sourced from CFT-90 datasheet, not from test). And it has lower Vf, so it’s clearly more efficient.
This may not scale to extreme currents like CFT-90 but nevertheless thanks to not-so-terrible efficiency it may be the new king of big throwers. :student:
Interested for 2nd batch
also interested for 2nd batch
please send me a PM - easier for me to answer asap
Anyone have any info in the rear clicky specs? Dimensions etc? Looking to put in a reverse clicky
Someone correct me if I’m wrong but I think it already has a reserve clicky.
