Embed a pic - looks like this will embed a pick of the S21 “Manta Ray” from ebay…
Thanks for the review.
Ordered one. When it comes will give feedback.
I have feeling that this will be very stupid question, but
I have just got new s21a from simon
is it OK if the light head is ratling? whole inside part is moving and glass is free to rotate and move…
Shouldn't do that.
(1) Make sure the pill is screwed all the way down. There are two notches on the pill - you can use needle-nose pliers to screw it all the way down.
(2) Make sure the O-ring wasn't left out (behind the lens).
max temps on convoy s21a
Would be interested a comparasion betwen S21A and S2+,same power config Driver and Led
wich of them dissipates better heat
My Convoy S21A.
It will be the same, as it have temp. control, so both will be stucked on 55°C
and btw, I dont thing that there will be any noticeable difference, as they are nearly 1:1 copy
depend wich arrive later at 55°C
That mean it have better heat management
but yes they are very similar,apart pill S21A that I like much,hope to see this pill in copper for single and triple/quad.
Spring bypass just ripped off from spring after 3months… On both sides
I guess its ’cos cable isolation become very stiff due to heat
At least it is easily repairable! The reverse threading of the switch end can be a bit of a pain though.
I wonder how the SST40 would perform with a straight FET+7135 driver in the S21A?
So far I’m adoring the Cree XPL2-HD with the MTN-20DDm in the S21A.
Spring bypass just ripped off from spring after 3months… On both sides Convoy s21a broken cable - Album on Imgur I guess its 'cos cable isolation become very stiff due to heat
I use solder wick, massive current flow and worry free
I’ve seen solder wick broken so many times I won’t use it for a bypass, don’t even own any. I use Turnigy wires and always try to put a bit of a coil on them so they compress rather than bend.
One more question:
How it is with waterproofness on this light? Can it survive dipping into water for few minutes?
One more question:
It does have the required gaskets and if ya build it right, they should do the job of protecting itself from the occasional dip a puddle.
I like if Convoy would use quality double springs and button top on Driver instead of spring bypass to avoid wire desolder.
I don’t like button contacts on the driver. I consider it much better to have springs at both ends of the light.
That way you don’t get a momentary disconnect if you drop the light on its tail and the cell pulls away from the driver button as it bounces on the tail spring. Those momentary disconnects create an unwanted mode change on lights with reverse clicky tail switches and a half-press mode change UI. Really annoying if your light just went from moonlight to turbo or vice versa.
Springs at both ends also help to prevent “cell hammer”, which is what happens after a really nasty drop where the tail spring propels the cell back into the driver with such force that the driver PCB cracks and kills the driver.
Spring bypasses with multi-stranded flexible silicone-insulated wire are the value option, and double springs (as you said) are the gold standard.
I was asking because I needed to illuminate dark basement while working for few hours, so I was thinking about putting the flashlight into glass of watter to keep it cold, so it could run on turbo for infinite time
Could anybody tell me the diameter of the battery tube? I want to buy one shockli 21700 4550 22a/30a for the s21a that is coming but I think it will be too thick.
Thank you
I measured 21.48mm with my calipers. I use Samsung INR21700-48G which fit just fine.
