Archive topic - Banggood & Fin17
2019/10/22
2019/10/23
Fireflies E01
Osram
$ 29.9
code: FINEEO1
PALIGHT 26650
5000mAh - 1Pcs
$ 6.55
code: FINpl266
HLY 26650
5000mAh - 2Pcs
$ 7.99
code: FINhly266
2019/10/24
PALIGHT F80S
XPL HI 1900lm
$ 43.99
code: FINf80s
NAME
PALIGHT RX-PLUS 1380lm
$ 28.99
code: FINrsp
XANES AL037
XPL HI 1000Lumens
$ 19.99
code: FINAL037
QCY M1 Pro
Magnetic Earbuds
$ 20.02
code: BG20QCY
Looks like the lowest price ever for Wiha. But I spent too much recently…
It’s really nice. It’s also quite useful unlike having another light that you don’t need. I can recommend this product.
Yes, Wiha products are good!
Maybe I ask for coupons for other Wiha products?
XIAOMI MIJIA Wiha 8 In 1 Ratchet Screwdriver
XIAOMI Mijia Wiha 26 In 1 Multi-purpose Screwdriver Set
Wiha Zu Hause Electric Power Screwdriver
Wiha 17 in 1 Daily Use Screwdriver Set
Wiha Zu Hause 20V 200NM Cordless Electric Screw Driver
Wiha Zu Hause 20V Cordless Dual Speed Electric Drill Driver
Wiha 6inch Needle Pliers High-carbon Steel
Wiha Wire Cutter 6inch
Wiha Hex Wrench 9 Piece Set Crocodile Screwdriver Kit
I’m certainly not in need of anything these days, but I also enjoy seeing good non flashlight deals.
2019/10/25
XANES
T6 18LED
$ 38.99
code: FINKKKA
Is the Roxane light available with a red LED?
:smiley:
No,only white XP-L2
Soft diffuser, Type-C charging cable and 21700 battery included
SAMSUNG INR18650-35E
4Pcs
$ 17.99
code: FINss4c
2Pcs
$ 9.99
code: FINssc
Thanks Fin17, ordered S43S copper :+1:
Do you have an interesting code for Rot66 Osram ?!
thanks an greetings, LitN
【 ACTIVE 】 FIREFLIES ROT66 Generation II SST20 / XPL HI / OSRAM ✺ BEST PRICE EVER FOR SILVER VERSION
2019/10/29
2019/10/30
Convoy C8
LG 5W UV Flashlight
$ 27.69
code: BGC8UV
LUMINTOP FW3A
SS Bezel
$ 3.39
code: BG162
Finn17, can I get a code for the PL47 Gen II please. :smiley:
“Convoy C8 LG 5W LED Powerful UV Flashlight Fluorescence Detection Lamp”
What wavelength is this, please? And is that a ZWB2 filter I see on it?
Convoy’s AliExpress Store lists this item here, I suppose that’s the same item:
indicated specs are:
