Looks like the lowest price ever for Wiha. But I spent too much recently…
25.23€ 18% OFF|Convoy C8 mit UV365nm LED, umfasst extension tube,UVA 18650 Uv...
Smarter Shopping, Better Living! Aliexpress.com
It’s really nice. It’s also quite useful unlike having another light that you don’t need. I can recommend this product.
Yes, Wiha products are good!
Maybe I ask for coupons for other Wiha products?
XIAOMI MIJIA Wiha 8 In 1 Ratchet Screwdriver
XIAOMI Mijia Wiha 26 In 1 Multi-purpose Screwdriver Set
Wiha Zu Hause Electric Power Screwdriver
Wiha 17 in 1 Daily Use Screwdriver Set
Wiha Zu Hause 20V 200NM Cordless Electric Screw Driver
Wiha Zu Hause 20V Cordless Dual Speed Electric Drill Driver
Wiha 6inch Needle Pliers High-carbon Steel
Wiha Hex Wrench 9 Piece Set Crocodile Screwdriver Kit
I’m certainly not in need of anything these days, but I also enjoy seeing good non flashlight deals.
Is the Roxane light available with a red LED?
No,only white XP-L2
Soft diffuser, Type-C charging cable and 21700 battery included
Thanks Fin17, ordered S43S copper
Do you have an interesting code for Rot66 Osram ?!
thanks an greetings, LitN
【 ACTIVE 】 FIREFLIES ROT66 Generation II SST20 / XPL HI / OSRAM ✺ BEST PRICE EVER FOR SILVER VERSION
Finn17, can I get a code for the PL47 Gen II please.
“Convoy C8 LG 5W LED Powerful UV Flashlight Fluorescence Detection Lamp”
What wavelength is this, please? And is that a ZWB2 filter I see on it?
Convoy’s AliExpress Store lists this item here, I suppose that’s the same item:
indicated specs are:
LED: LG UV 365nm LED
Driver: input 3-8.4V, output 1500mA (single mode), low voltage warning 2.8V/5.6V
riffraff:“Convoy C8 LG 5W LED Powerful UV Flashlight Fluorescence Detection Lamp”
25.23€ 18% OFF|Convoy C8 mit UV365nm LED, umfasst extension tube,UVA 18650 Uv taschenlampe, taschenlampe, UV UV365|Taschenlampen| - AliExpressindicated specs are:
Thank you. :+1:
