Titanium: very nice strong material but very bad thermal conductivity which rules out its use for any high-powered flashlight for me
Copper: excellent thermal conductivity but high weight and also copper/copper oxides are toxic and nothing that I want in contact with my skin all the time
I guess for each their own. To my eyes chips and scratches are damage and as noted - they tend to really stand out with alu typically having a very different colour from anodization.
Oxidation is not damage to me. It just forms some pattern. Scratches and dents happen too…but normally they are not standing out that much. Actually patina hides them a bit.
To me it’s the opposite - when on a trail I don’t care about looks and take something lightweight. Reliability? Connections are the things that fail the most for me, I’m yet to experience a body failure.
And redundancy is king. I did have a double-failure (and walked with a cell phone light) but such cases exceedingly rare.
I often hold my neck lights in my mouth. For just this reason I have mixed feelings about that Astrolux A01 Cu…
I like the lightweight Ti offers plus its shiny (well, sorta). I love the smooth, shiny finish of my SS lights… but aluminum really does work great. With a quality HA finish, especially in olive or natural, they look good for a long time, plus a bit of pocket wear on the EDC only ads character.
Titanium: if you don’t care about electrical conductivity, TIAl alloys offer superb yield strength and resistance per weight, so a 4mm thick battery tube can be shrunk down to 2mm, granting you weight savings. Also, since base hardness is higher than aluminium and steel, it doesn’t scratch as easily. Chemical resistance is superb.
Other than that, in the context of flashlights, it’s actually worse than aluminium. More expensive in alloy form. Significantly more expensive in pure form. Actually denser. Much worse electrical and thermal conductivity.
The best application for it in flashlights are weight savings in the battery tube.
Aluminium: Quite low cost. High electrical and thermal conductivity. Lowest density. Easily machinable. Thick anodization can actually make it super durable. Good resistance to corrosion and basic oxidation. Highest thermal capacity per weight.
Worse thermal and electrical conductivity per volume vs copper. Softer than steel and titanium alloys. However, good anodization, as mentioned before, can make it super durable.
Very poor chemical resistance. Most environmentally friendly in terms of mineral extraction and availability.
Copper: Best thermal and electrical conductivity. Easily machinable. Decent chemical resistance. Highest thermal capacity per volume. Can easily be electroplated for some gorgeous surface finishes.
Extremely dense. Very high cost. Softer than aluminium. Oxidizes quite rapidly. Very bad environmental costs in terms of mineral extraction and availability.
Stainless steel: Lowest cost. Highest resistance if weight isn’t a concern. Very high chemical resistance.
High density. Very poor thermal and electrical conductivity. Making stainless steel is actually quite environmentally friendly in terms of mineral extraction. Chromium however, especially hexavalent chromium…
copper is heavy, soft, turns a color i don;t like, and can make your hands smell funny
brass will do that too, make your hand smell funny
ti is lighter, but not really that hard, and expensive, and not a great heat conductor
i do not have a titanium bike either - aluminum is fine for bike and flashlight!
aluminum is cheap and can be anodized pretty colors, heat dissipation and cost are ok with me
“You never have the wind with you - it’s either against you, or you’re having a good day.”
—Daniel Behrman, “The Man Who Loved Bicycles”.
Above.
That pertains to us sailors too mate. Running and reaching only.
Stainless. Nice and shiny.
AND heavy.
Copper goes lovely varying shades of dark and light.
and heavy. Great.
I dislike artificial looking shiny bright Copper. Brass.
Aluminium.
Black, Med Grey, and RED.
Nicest of colours. Heated. Any colour brings out a nice shade too.
It’s all personal. I prefer Med Grey and Black to anything else in a torch.
Heavy and stained Copper for my “different”, and stainless ones.
Nichia 219b, and Cree 5000ish in LED,s.
Convoy C8+ in Copper. MY next waited for light. NW beam.
Copper looks good especially those old potstills. A bit of useless information, they use copper to get rid of the sulfides from the ferment and it gives you a better drop of alcohol.
CPU heatsinks with a copper slug work better then just having aluminium to transfer the heat. I like the led to sit on a piece of copper to give it more thermal mass it also adds surface area to transfer the heat into the aluminium body. I cut the shelf out of the L6s and and solder the LED to a threaded copper slug this screws in in place of the shelf. Thermal paste on the thread. Only my opinion but the light seems to handle the heat a lot better.
I’m surprised to see so many comments regarding the thermal conductivity of copper but only one mention of emissivity.
Conductivity is important for, well, conducting heat from the source to the outer surfaces of the light. Copper is great as a PCB core material. However, the total power a light body can dissipate to its environment depends on the surface emissivity of the body material, not its conductivity.
Copper’s emissivity is quite poor compared to anodized aluminum. That means that a copper-bodied light needs to have a higher surface temperature than an anodized aluminum light to dissipate the same amount of heat. Stated differently, for a maximum allowable surface temperature, the copper light needs to run at a lower power level than the aluminum light.
Combine the poor thermal performance with the higher cost, much higher weight, and poor corrosion resistance compared with anodized aluminum and copper just doesn’t make sense to me as a flashlight body material.
I don’t think this is correct. Emissivity (radiation) is only one way of heat dissipation. The other way of heat dissipation is conductivity; heat being transferred from copper surface to surrounding air. You need to look at total heat dissipation in order to evaluate which is better.
Copper is germicidal. Some people dislike the metalic smell of their hand after use. Copper does not stay shiny, but is easily repolished. Touching copper, or storing water in copper, produces too low a dosage to be toxic. The health benefits of copper touch surfaces, outweigh the risks. I find copper flashlights larger than AAA too heavy for me to EDC.
Titanium stays shiny. It is is hypoalergenic. (used to anchor dental implants)
Anodised aluminium is a surface coating that wears off, exposing raw aluminium, which is toxic.
You’re correct that radiation only accounts for a portion of the total heat transfer. The remainder is through natural convection (assuming our light is just sitting in the air with no forced air flow).
However, the rate of heat transfer through natural convection does not depend on the conductivity of the surface material. Rather, it depends on fluid properties like density, viscosity, conductivity (of the fluid), etc. And of course the temperature of the surface and the fluid. Natural convection is driven by how effectively the fluid can transfer heat through itself and how well the temperature gradient induces natural flow.
