This is an eye nut actually but yes, I bought a few on ebay, rvs M3, especially for this mod because I could not think of a nicer way to attach a ring
It was a E14 bulb in my case, of this type (pic shows E27 version):
But I think this specific type with smooth illumination is not sold anymore, it is all irregular optics now, apparently people like irregular illumination better.
Kinda reminds me (in functionally) of the night light I rigged up in one of my kids’ rooms: a Sofirn SC31 with a custom driver (made for ultra low power and has a watch crystal to keep time so it turns itself on and off). Looking at your creation, I wonder if I should 3D print a diffuser to make it more of a lantern like yours (currently mine is just doing ceiling bounce).
SC31B from their Amazon promo, originally had a SST-20 ~6750K, cool white by anyone’s definition.
Got a little refresh with LH351D 5K 90CRI and the 18350 body tube from SP40. Bezel had to be removed with pipe wrench + old piece of belt. It’s not loctite but it’s not gonna come off with your sandal
Slight yellow halo in the edge of the corona but the hot spot is nice and defined with the spill looking clean. I may slice it some day but for such a cheap light I may not just to keep the max lumens higher. ~675lm on max.
You didn’t happen to grab any pics of the driver, did you? I’m curious if they actually updated it since the SC31 and if the layout is the same/similar.
I've never used an emitter with this low K value as I thought I wouldn't like it but it's not too bad for a little mule.
After seeing Djozz lantern post I decided to make a wee diffuser for it too from an old berocca tube.
It was recently a H03F with optional diffusor over the reflector, but it broke.
It had a SS bezel from a laser cutter and dc-fix milky foil.
And it had already a lexel-driver with narsil.
Now I have swapped the XM-L2 to a XHP50.2 3V. And I opened the bezel to a 45 degree opening as the original SS-bezel.
It makes around 2000 lumens at start, because the led-wires are original, that means thin and relative long. But it heats up quickly and I do not need more power.
And I repaired my SIOC8 programming clip. There were some bad connections.
Later I want to flash anduril with ramping-level of 50%.
I took out the SST40 and driver of my Convoy L21A and replaced it with a 22mm 14* 7135 driver and a Led4power mcpcb with a 1mm white flat and one of Simon his 3030 gaskets which i sanded down to get a better focus.
Result is a very impressive laserbeam (500+ kCd on a ~4V cell)
Nice combo Yokiami!
Maybe it is time to do what the Canadians did and have a dutch meet-up, next to a nice line of windmills to check out some throwers.
Next in line to mod:
Eagletac M25C2 Turbo - with XP-L Hi
I started to dislike 219C because of the Greenish tint, but after mixing CCT’s, I lowered the DUV without compromising on output and resorting to LEE filters. Same applies to SST20. Used the Bluesword lower DUV bins, and mixxed CCT. At the moment, only my Zebralight SC5C and SC600w Plus have Lee filters on them.
