Hi. I recently got a mf01s and i have challenges ramping above 100 or turbo mode and tactical mode. If i do any of these modes i get a very bright flash and the flashlight turns off. No way to get it back on unless disconnecting the batteries.
Ive used keeppower 3500mah with protection and max discharge of 10A per battery. Should be sufficient. I have also calibrated the temperature sensor. What else can i try?
Ok. So what protected batteries can you recommend? And how big is the difference between 145-150? To be honest, the heat is already worrying at 145 so i might just not care…
Keeppower 3000 can handle more current and should be fine. The cells are 15A rated Samsung 30Q and the PCB trips at around 20A.
I don’t think you’ll notice much difference between 145 and 150; very bright, very hot fast. :sunglasses:
Not knowing what part of the world you’re in it’s hard to recommend batteries. Being that they all run in parallel and not series unprotected matching cells can be used. I think the best for your turbo desire would be.
Samsung 30Q 18650 3000mAh 15A or LG HG2 18650 3000mAh 20A with button tops and unprotected.
