at $16, id rather spend a bit more and get the h03 which i find to be worth the price difference by a long shot. i have both lights and the boruit leaves a lot to be desired. h03 is great out of the box. but id get another d10 if one went on sale.
That’s like $30 when on sale. To me, that’s more than a “bit”. Plus it’s an L shape design with no built in charging. Then you have that single click On, press and hold for Off nonsense. No thanks. Lol
idk why you are arguing what my preferences and opinions are on a purchase im going to make. its not like you are going to change my mind. at $16 i dont find this to be a better deal than a h30 for my uses and preferences.
im also not in a hurry to buy it, so why not wait till it drops in price like it has many times in the past? im just looking for a spot to catch said deals.
Sorry, bad choice using constant to describe the output. I meant to say that my cheapo Rayovac headlamp has very annoying steps when the output drops, but the D10 seems very linear and not noticeable.
Does this light have the motion activated mode like the RJ02? After a emitter swap I really enjoy the RJ02. So did my one of my brother in-law’s. He’s a mechanic and not a flashlight guy. You would have thought he struck gold when he found out he could wave his hand in front of it to turn it on.
In my opinion, using 7135 regulators is like driving with an old banger, a rattletrap. There are plenty of nice high power MOSFETs which can be used in linear mode, avoiding the less than ideal regulation of 7135s when PWMed and completely doing away with such undesirability.
Thanks for sharing. So it uses a dual board e-switch driver, could you share its dimensions? Diameter and total height. I wonder what other good e-switch drivers could fit inside.
To fix hardware is not big deal, real problem is to get proper firmware to run it. Ordered few pcbs with FET+1. Gonna try to run Anduril. Stock driver size 20.7x19mm.
Hello there, I just received my lamp and I’m preparing to replace the MCPCB/LED, what the easiest way to go about taking the old board out? I understand it is difficult do to the thermal glue. Any tips are appreciated.
I use needle nose pliers and carefully but firmly twist it loose. You can remove wires first and tuck them out of the way so they don’t get cut during the twist.
