HKJ
(HKJ)
October 12, 2019, 3:30pm
1
Vapcell INR18650 2600mAh G26 (Red) 2019
Official specifications:
Model:G26 INR18650 2600mah 25A
Nominal voltage: 3.60V
End-of-charge voltage: 4.20V
End-of-discharge Voltage: 2.5V
Typical Capacity: 2600mAh (0.2C discharge)
Min capacity: 2500mAh (0.2C discharge)
Weight: Max:47g
Internal resistance: Max:10mOhm AC 1kHz
Standard Charge: 2000mA,CCCV 100mA cut-off
Quick Charge Current: 4000mA
Max Continuous Discharge Current: 25A
This is a high current 18650 cell with moderate capacity.
The two cells matches very fine and capacity is nearly constant independent of load.
Conclusion
It is a good high current cell, that can deliver the rated 25A without any problems.
Notes and links
The batteries was supplied by Vapcell for review.
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
Thanks HKJ! Looks like the LG H26.
JaredM
(JaredM)
October 21, 2019, 1:49pm
3
Looks like. I didn’t realize that LG changed their cell structure so much. Not only are the labels different, but now they use a ‘3-leg’ positive pole like most other manufacturers. This will make discerning re-wraps and fakes a bit more difficult IMO.
Regardless of that, we appreciate the fine review as always HKJ !!
shadockan
(shadockan)
October 29, 2019, 4:40pm
5
It’s great to talk to a company that has the courage to mention which battery it uses.
Thanks for telling the truth Dennis.
This counts very much ……
We also thank our dear friend HKJ, who once worked for us …
HKJ
(HKJ)
October 29, 2019, 4:44pm
6
I test batteries for whoever send them to me, only limit is how fast I can test them.
You are so great and selfless. :+1:
salute
Sirstinky
(Sirstinky)
October 30, 2019, 4:36am
8
yeah ,you are right
I like transparency in the battery industry in China! Kudos
Barkuti
(Barkuti)
October 30, 2019, 4:54am
9
Only Samsung tops come close to that geometric shape, but still is easily discernible:
Left: this cell; right: Samsung 25S .
shadockan
(shadockan)
October 31, 2019, 6:41pm
10
Not only Samy …
LG MH1 has the same …… I think …….
