At the moment, I am testing/charging one partially discharged 30Q. (Actually, my first time to fully charge a cell, so I donāt know how it terminates!)
Here are the initial photos:
Tapped the #1 bargraph, then this screen appears to choose charging rate. I tapped 2a, itās highlighted, albeit poorly!
When ātypeā is tapped, screen will show the auto detection of cell chemistry, in this case the 30Q is Li-ion 3.7 ( the Li-ion 3.8 is for some special cells that terminates at 4.35v)
Thanks very much for taking the time to show this
But I was more interested in confirming that the actual battery voltage is accurate by using an accurate multimeter to see if the chargers idea of 4.2volts is really 4.2 volts.
In other words is the charger calibrated properly.
While most modern, well-designed chargers of today terminate @ 4.20v, almost all batteries, if not all, almost immediately go to their ānaturalā resting voltage of below 4.20v anyway, for me, I have no practical purpose of checking about exact voltages to the thousandths of a volt.
Iām not sure if this post is aimed at me ,I think it may be so Iāll reply,
Iāve read HKJās review , heās very good & I highly rate him,
But Iām not sure if he has time to verify each test with a multimeter because heās very busy with the amount of stuff he tests , so Iām sure heās talking the termination volts from the chargers display, I have bought & use charges heās tested & ive bought because he said this or that charger terminates at 4.2v but when Iāve tested them they usually fall a bit short eg 4.16 ,4.17 etc , or maybe if he has got time to verify that it terminates at a real 4.2 then itās possible manufacturers may cherry pick before sending to him because their credibility is on the line.
Sinical old meā¦
Yes I agree with you BUT Iām not talking about a cell staying at 4.2 v ,it is obviously going to settle to around 4.18 after a while , Iām actually talking about cells leaving the charger STRAIGHT after the charger says full @4.2.
If itās actually terminating at 4.17 v verified with accurate multimeter but charger reports 4.2
Then the cell will settle at something like 4.14-4.15v ,I hope thatās made it clearer to understand.
My curves are made with a 6Ā½ digit multimeter and I read the termination volt from them (From the curve, not from the logfile).
Termination voltage is highest voltage while current is on, as you can see on all my curves voltage drops immediately when current is turned off.
Iāve stoped using the all88 charger with lithium ion because if I check the voltage a day after charging the voltage is 4.13 ā4.16 (the gyrfalcon isnāt consistent on all slots) but if I charge on mc3000 they read about 4.18 v a day or so after charge ( I set termination to 4.2v )
Hey HKJ ,Do these manufactures know you are going to publish your tests on forums
Is there a chance these are cherry picked for reviewers ?
Do you actually get mainstream production units ? Iāve noticed you sometimes donāt get the retail boxes
Maybe itās the luck of the draw & some chargers of the same type are accurate & some not so!
Well anyway Iām very happy with my two mc3000ās ,my opus (after modifying) &my xtar vc4 they all terminate at a verified 4.2 ,the rest stay in their boxes.
When I say the charger is supplied by the charger manufacturer, like the Xtar, Eizfan, Golis chargers. When I buy the chargers or they are supplied from a shop the manufacturer will not know it.
Mostly no, I do sometimes get defective chargers for review.
Missing retail boxed is either early production units, from Ebay or from a reader.
The charge voltage will vary for copy to copy of a charger, how much depends on the quality of the parts used and if they do calibration.
It seems to me that everything is very simple. If you want the voltage on the cell to be as close to 4.2 V as possible, choose a charger that is as low as possible with a cut off current and, as a result, a longer charging process.
For example:
MiBoxer C4-12 - cut off 60mA. 18650 taken out of the charger - 4.195V.
I think the C4-12 sometimes shows 0.06A and sometimes 0.05A (to verify) end-charge current before it indicates āFullā.
And youāre right, when I use a DMM to test the battery voltage (right after it becomes āFullā), then the battery voltage is really really close to 4.20v (oftentimes just +/- 0.005v from 4.20v, so like 4.195-4.205v)
What is now top 26650/18650 cells charger? My MC3000 died yesterday and now I think what to buy, 4 or more slots? And maybe what as spare 4 slot charger? Should I buy next mc3000 or s4 or something else?
I think the MC3000 is still one of the most advanced charger (if you like custom programming the charging currents or have a need to adjust the ending voltages, either for charging or discharging tests). Otherwise for charging only, I like the Miboxer C4-12 (although they seem to have a slightly high failure rate in some slot, at least per my experience).
Kajman, that is interesting. Mine has problems in the second slot and I am looking for an alternative, and the first charger I thought of was this exact same one. With display etc. Not sure "how good" it is though, compared to the MC3000. Shame on SkyRC when they break within 2 years. Mine was a 2018 model.
Mine died after 9 month, bought from China, so no warranty. First I got mcp3424 error, I changed chips, but keyboard had still no function, later magical things happened with display and it died. It seems,that it is middle quality, inside looks not much better than my old li500. And I never discharged cells with it, I use rc chargers for this purpose. Ehh, but if there is no other, I will buy mc3000, but locally with 2 years warranty
