5000 m, 3.1 miles from a XM-L2, 146 mm diameter alum reflector. Might be interesting with a SBT90.2 at high amps. Looks like 4 18650's: 2700x4 = 10800 mah. Plus has a red light and side light, USB charging, etc. Lots of things for $56 shipped.
The claimed lumens output is a realistic 1000 lms, so you gotta wonder bout the claimed throw...
Realistically it's impossible - 5000 meters would be 6250 kcd. I'd be impressed if it did 600 kcd with a stock XM-L2, but there's potential with such a big reflector and actually with a small investment. I know there's been other efforts here on BLF with some large, cheap reflector lights and I think they all ended up a bust.
You are not right… There are other China 21700 zommies out there… And the one I saw is made for 1x 21700 cell, had 3 x inbuilt led emitters (white, green, red) switchable by a knob on flashlight + additional dimmer switch to control brightness of each light mod (white, green or red).
It was declared as a hunting light but to large and heavy for hunting light imho. But it really does have cool features as handheld flashlight.
I like the deep Haikelite fins. This light looks better than the MT09R. Looks like it has a copper shelf?
Any advantage of the SST70 over the XHP70.2? What is the advantage of this over the MT09R?
The only thing I didn’t like about the MT09R is that it doesn’t have any active thermal regulation. The light just gets dimmer and dimmer until it drops to like 400 lumens. I wonder if the updated Narsil incorporated active temperature regulation like Anduril.
No full thermal reg, not as far as I know., but then again, I don't know anything bout this light til now. Looks a little clunky. Dunno anything bout the SST70's though - are they 3 or 6V?
Thanks djozz, another great LED test! All depends on the throw advantage, but having all those wires, might be a challenge to dedome? Then again, the better LEDs for dedoming seem to have wires...
