Proprietary battery if you want to use the built-in magnetic charging system.
No. This light will not turn on with any cell other than the proprietary one Olight sells for almost $30.
LumenMax: bmengineer:30% off only today, but proprietary cells only forever. No thanks.
Sean @ Olight stated that you can use other batteries with this light. You cannot charge them with the magnetic charging system, that's all.
The answers to questions on their product page and word from a reliable source with the light in hand disagree.
Sean tried a button top non-Olight battery and it works for him. 18.2Wh, 3.6V battery.
John Bean is a member of Vimeo, the home for high quality videos and the people who love them.
Is this the Acebeam battery used in the video? https://www.batteryjunction.com/acebeam-21700-li-ion-battery.html
Oh man, what a sad thing you did there Olight.
Sean will look into this further.
The part number matches the one seen in the video.
That is absolute BS! We were told in the FB group that it would work with a non-proprietary battery, as does the Seeker Pro. Not only did I already order the light, I also ordered a non Olight 21700.
If this is the case, I’m done with Olight.
Thank you for posting that! I sure am glad that I scrolled down to read what others have posted.
I was about to purchase for that price. I EDC an Olight. I have two, but if this is what they are doing I may never purchase another.
On Amazon, In the description it just says Powered by: Customized 5OOOmAh 21700 Rechargeable Lithium Battery
That is absolute BS! We were told in the FB group that it would work with a non-proprietary battery, as does the Seeker Pro. Not only did I already order the light, I also ordered a non Olight 21700. If this is the case, I’m done with Olight.
I have the Seeker 2 and Seeker 2 Pro. The Klarus 21GT-50 battery works in both.
That’s not true. I just tested my copper M2R and it turns on with my VTC6 button top and Molicel P26A flat top.
pconig:That is absolute BS! We were told in the FB group that it would work with a non-proprietary battery, as does the Seeker Pro. Not only did I already order the light, I also ordered a non Olight 21700. If this is the case, I’m done with Olight.
Yes, my S2 Pro also does work with all of my 21700 cells, not just the provided Olight cell.
bmengineer: LumenMax: bmengineer:30% off only today, but proprietary cells only forever. No thanks.
We’re talking about the M2R Pro here, its a totally different light…
I gave my thoughts on why this light will probably not work with a regular 21700 contrary to the Seeker 2 Pro here: PSA: the Olight M2R Pro requires a proprietary battery to work at all - #11 by kanton
Short version: The battery goes in the other way around than in the Seeker 2 Pro. They seem to use the Plus and the proprietary Minus to drive the light for the M2R Pro. They used the regular Minus to drive the light in the Seeker 2 Pro.
Regarding the regular M2R: This light is constructed COMPLETELY differently, and has an inner tube (like the FW3A or Klarus lights) so it can use a standard 18650.
Yoiks!
If I bought the light from Amazon, tried (several) standard 21700s, and it wouldn’t work, I’d have to return the light as defective. How could I or anyone else know it would only work with a proprietary cell?
I’ve bought several olights. They finally get the neutral>cool white and then get greedy on a $30 battery?
