Emisar D1sV2 respectively Noctigon K1
Integrated USB-C charging is awesome, it will directly compete with FT03 :smiling_imp:
Awesome! This would be my first CW thrower. And my first 21700 light… Waiting for the specs for the other LEDs. Hope it will be below $60.
I think I may need one of these, with a 4000K SST-20.
Yup, I have a collection of FW3A pulls and one will definitely be going in this light.
I also hope Hank will release an aspheric kit later on. Prometheus/47s just released an aspheric kit for their quark. That would be amazing for this light.
What size is the mcpcb? I hope it will fit a SBT90.2.
21700 and USB-C is the thrower I’ve been waiting for :+1:
Also hope there will be a SST-20 2700K or LH351D shaved dome version. What the market lacks is a WW thrower to cut through fog.
Looks amazing! better than i thought. Please make an SBT90.2 version as well. We’d all love to see it. It’s 3v as well so the driver should be cheap and easy to manufacture.
If the light will use a constant current buck or boost driver, I’ll cave and buy my first Emisar.
+1 for Warm/Neutral white options.
Ooooooh....SBT90.2.....even now am thinking to place it in one of present throwers just for a test.
Gorgeous work, Hank! :heart_eyes:
I’m glad to see the Noctigon name. I always liked it. :+1:
More photos, please! :partying_face:
Oh! that was pretty!!
If it can use a white flat, it can use an SST-20, and Hank has previously been willing to put emitters he stocks in his lights even if they’re not on the order form. SST-20 3000K should be an option. I’m aware of a couple people having special ordered the D1S with an SST-20 with a disclaimer that the emitter might burn out.
What I’m most interested in knowing right now is whether it delivers full output when the battery is low (before any low-voltage stepdown/warning/cutoff).
Same. Just sounds more…expensive. Much prefer Noctigon K1 to Emisar D1Sv2. i mean the sun would’ve already risen before you’ve completed the task of saying the name.
Any care to elaborate on the driver/ regulation? Buck/ Boost driver? Any idea of what sort of UI are we looking at? Very excited for this!!
I’m getting at least two of these for sure. SST-20 and Osram. SBT-90 would make 3. Single 21700 is a great setup for a super-thrower, while not being seriously over-encumbering.
OH, what about colors?
UI? Should be on/off :slight_smile:
Mike
Awesome!
Any 18350 tube possible? The design looks really nice. Other colors than gray maybe?
Wow, looking sharp!
Dang, good sounding light! I am curious about the change in name from Emisar to Noctigon. I figured the Noctigon name was a thing of the past.
Looks good! Is that a stainless steel bezel?
Hank, could you add an SST20 95CRI (3000k or 3500k or 4000k) as stock light option? A lot of people is interested in this version, as I am. Big reflecter and regulated driver makes all sence for this Hi CRI throwy led.
