If it can use a white flat, it can use an SST-20, and Hank has previously been willing to put emitters he stocks in his lights even if they’re not on the order form. SST-20 3000K should be an option. I’m aware of a couple people having special ordered the D1S with an SST-20 with a disclaimer that the emitter might burn out.
What I’m most interested in knowing right now is whether it delivers full output when the battery is low (before any low-voltage stepdown/warning/cutoff).
Same. Just sounds more…expensive. Much prefer Noctigon K1 to Emisar D1Sv2. i mean the sun would’ve already risen before you’ve completed the task of saying the name.
Any care to elaborate on the driver/ regulation? Buck/ Boost driver? Any idea of what sort of UI are we looking at? Very excited for this!!
I’m getting at least two of these for sure. SST-20 and Osram. SBT-90 would make 3. Single 21700 is a great setup for a super-thrower, while not being seriously over-encumbering.
Hank, could you add an SST20 95CRI (3000k or 3500k or 4000k) as stock light option? A lot of people is interested in this version, as I am. Big reflecter and regulated driver makes all sence for this Hi CRI throwy led.
I don’t think so, as far as I know, the SST90.2 willl need 20A+ to push it to the maximum
performance, the stock driver can not deliver such high current.
