Convoy 17/22 mm SST40 Driver temperature protection removal
In what reviews I spotted of the SST40 based S21A, when you engage Turbo Mode, it almost immediately starts stepping down, pretty much negating anything useful of that mode.
I might do a runtime test of my S11 w SST40 that I’ve taken to 7.2A…
Cant wait, will do mine once resistors arrive.
Already removed NTC.
I left the NTC on…. it gets pretty hot at 7.2……
Also did S2+ M3 M21A M21B.
I’ll risk it, much improvement in output?
300-400lm I think - I’m basing it off this:
My lumen tube isn’t quite ready :frowning:
I gained around 300 lumen with an R050 on the SST40.
The FT03 is still brighter, its driven quite hard
Wow, so bad?
I have to replace the driver in my nephew's S2+, torch predominantly used with the short tube, guess I won't mess with thermal throttling in that one. The other driver, though, is another story.
Hello guys
What about the Convoy M3 driver ?
How can i remove it?
Maybe this thread helps, driver might be sonewhat different though
The M3 has different driver, I’m not sure I find it correctly =((
I think i found it =D
Good info. I just ordered a few of these and I’m sure I will do this mod.
These drivers with the stepped modes look like constant current linear mode FET drivers like led4power’s. Is the other ‘ramping’ driver from convoy mentioned above also this type of driver? The description and UI seem strange. Is the current limited to 8A?
Hi Barkuti & folks,
Can I ask, where is the sense resistor on this board to be sure?
I have ordered the 20mm board 6A version which I supposed is the same as the 17mm/22mm one. Would you be so kind to show me where it is? thanks
Look at your link picture and it clearly shows R010
The sense resistor is that big R010 chip resistor onboard, down there in this photo:
That looks to be 2010 imperial size.
Thanks for the reply, Guess what? I have bought the 1210 sizes and its on its way! Haha, I read it off other threads of the similar driver but in a 17mm size I think?
Since 2010 size is 5mm x 2.5mm and 1210 is 3.5mm x 2.5mm, I suppose this allows me to join two resistors serially to lower the output (which was my main objective anyway).
I actually do see another R010 on the board, at the left side of the 10pin IC. Could that be the sense resistor as well? Regs
The sense resistor is the small black one at the very right of the board in that pic; “north east” of the MCU
Oh thanks for the double confirmation. Looks like I will be having a tough time trying to fit 1210 resistors there :smiley:
I don’t think you’re correct. Barkuti has modified these boards before so I’d be more inclined to trust his answer
