Hank, could you add an SST20 95CRI (3000k or 3500k or 4000k) as stock light option? A lot of people is interested in this version, as I am. Big reflecter and regulated driver makes all sence for this Hi CRI throwy led.
I don’t think so, as far as I know, the SST90.2 willl need 20A+ to push it to the maximum
performance, the stock driver can not deliver such high current.
There are actually two versions.
One is the 5A Linear regularted driver for the Osram, SST-20, XP-L LED.
The other is the boost 2A/12V driver which is for the XHP35 LED.
Hank, can you offer a custom build with Osram Ostar Projection Compact LE R Q8WP (625nm) with up to 700lm of red light at max. 5A i.a.w. the datasheet ?
I have this LED installed in theAmutorch New VG10 (bought from Neal) and it makes an amazing bright red thrower. This LED installed into the Noctigon K1 would be great and should perfectly fit to the driver specs.
