Emisar D1sV2 respectively Noctigon K1
Since regulated and with Osram LED, which 21700 makes best sense to buy?
I was planning on the Samsung 50E for 5000mah unless someone recommends otherwise.
Here, the 50E is your best bet.
Yes, that is right.
Yes, we do the customs build, bascially,
any 3535 footprint, 3V based LED can be put into it.
Take my money!
Would you consider SST90.2?
I don’t think so, as far as I know, the SST90.2 willl need 20A+ to push it to the maximum
performance, the stock driver can not deliver such high current.
Anduril UI, yes, fully regulated driver (not DD) with Anduril UI.
Hank do you have any thoughts on the different types of Osram leds in this light,
such as White Flat 1mm (CSLNM1.TG) vs White Flat 2mm (CSLPM1.TG)?
Hank, what kind of regulated driver?
There are actually two versions.
One is the 5A Linear regularted driver for the Osram, SST-20, XP-L LED.
The other is the boost 2A/12V driver which is for the XHP35 LED.
Yes, of course, I have tested both of them.
Stoked to see the boost driver! Thanks Hank
500kcd!!! Take my money interested! :smiley:
I’m in for this one. Love it, can’t wait! Thanks for the update.
Hank, can you offer a custom build with Osram Ostar Projection Compact LE R Q8WP (625nm) with up to 700lm of red light at max. 5A i.a.w. the datasheet ?
I have this LED installed in theAmutorch New VG10 (bought from Neal) and it makes an amazing bright red thrower. This LED installed into the Noctigon K1 would be great and should perfectly fit to the driver specs.
I’m a little sad this isn’t buck/boost or at least buck. I actually find myself contemplating XHP35 over SST-20 now.
Looks great!
I’m hoping for XHP35 HI CRI version then :sunglasses:
