I don’t think so, as far as I know, the SST90.2 willl need 20A+ to push it to the maximum
performance, the stock driver can not deliver such high current.
There are actually two versions.
One is the 5A Linear regularted driver for the Osram, SST-20, XP-L LED.
The other is the boost 2A/12V driver which is for the XHP35 LED.
Hank, can you offer a custom build with Osram Ostar Projection Compact LE R Q8WP (625nm) with up to 700lm of red light at max. 5A i.a.w. the datasheet ?
I have this LED installed in theAmutorch New VG10 (bought from Neal) and it makes an amazing bright red thrower. This LED installed into the Noctigon K1 would be great and should perfectly fit to the driver specs.
Yes it will only make sense on direct drive. The NI40 SBT90 pulls 22 with a 40T. Would really appreciate it if you could make a FET/DD SBT90 version :laughing:
Could also make it regulated but have turbo in direct drive.
