I agree, seems like people want to handle heat on this light but the body of the fw3a is paper thin and I suspect you wouldn’t be happy in an extra large pill to distribute heat
I think that’s a great idea. FW1A is only 8.3mm longer. By inserting a copper spacer inside, you can significantly increase performance.
I had two FW3A pieces from the first batch with a black clip and sold them, among others, because of the “paper” shelf.
This was my thinking, the FW3A is a great light but struggles with heat due to the thin shelf. A spacer in the FW1A might take the edge off of this problem.
@kiriba-ru
Are you able to extend the shelf for mcpcb in aluminum p60 pills? The new Noctigon mcpcb have a diameter of 23mm instead of 21mm.
I don’t want to use mcpcb from l4p.
I ordered some parts a few weeks ago and they just came in. The parts look great and I am very pleased with the purchase. Some of the items were “seconds” and Kiriba-ru was very honest and upfront about the issues. Excellent communication and service.
Still have some soldered S2+ triples in stock. They are not perfect (used spacers with misaligned central hole, also pill and spacer have loose for before soldering and this may cause second misalignment) and limited in quantity so I dont list them in first post.
Cheaper than ever, $6/pc.
Ive got one PM with MF01 mini driver heatsink request (ASTROLUX MF01 Mini - common issues thread - #25 by man_of_light).
Im not sure that I will be able to sell the batch, so I need to know if here is enough users interested in.
Im thinking about cheaper alu version, price could be $6/pc.
Clearance time is over, prices have been corrected.
MF01 mini driver heatsinks will not be made.
I will make one more P60 quad shells batch (both in Cu and Alu). Trying to make them ready before NY.
My Convoy M2 quad mod went very well thanks to kiriba-ru! I wanted an aluminum spacer to keep the weight down. I used Nichia 219B 4000K LEDs with a 10622 Carclo lens. The 10623 Carclo lens was too floody for me. What an awesome beam and tint!
