Flashlight Host and Uncommon Budget Flashlights
6V, I tested one, XHP50.2 format but a smaller die area.
Thanks djozz, another great LED test! All depends on the throw advantage, but having all those wires, might be a challenge to dedome? Then again, the better LEDs for dedoming seem to have wires...
Are you sure it’s not also available in 3v? Look at the battery tube, it looks like 4 cells in parallel.
It’s 4 + 4 cells; 2S4P
Not much is known about the SST-70 as it is not listed on the Luminus site yet and I’m not aware of a datasheet available. It would be a nice surprise if it came in 3V as well :slight_smile:
Okay, that makes sense. I wonder why the specs say it uses 4 button top cells? Maybe they copied and pasted specs from another light and it contains a few errors.
In this set-up you need button top cells both for driver contact and for battery-battery contact in the middle.
I asked TA if he worked on this light or if Haikelite is just adapting his older MT09R driver without his knowledge. If he worked on it he might have some insight into it’s performance.
Update, he didn’t work on it. Haikelite must have adapted the driver themselves.
That one is like Supwildfire(Mitko super thrower) on steroids and neck switch :slight_smile:
Xanes zoomable flashlight with 80mm lens: :sunglasses:
There is some discussion as well as links to cheaper (but potentially lacking powerbank) variants here
26650
127mm x 36mm
Thank you! It is really cheaper on Aliexpress.
I have a feeling it’s plastic junk but I like the use of 2*18650 and overall format.
http://www.aliexpress.com/item/32733422105.html
One can assume light has unbranded emitter installed when you see "CREE T6" for specs.
This could be the weirdest flashlight for 2019
That switch looks like convoy BD series with recharge contact points. Weird looking light
As do I, but would love a 21700 type, slap on an L2 Head… hmmmm
Definitely not liking the Plastic Fantastic. Looks REALLY cheap.
