The new Haikelite HT70 is listed on Taobao now. Just searched for Haikelite’s 11/11 offers on Taobao and there it was! I have already seen a leaked foto of it here on BLF and I really like the design. It has 8 18650 batteries and 4 SST70 leds in NW or CW in a big smooth reflector doing 17000 lumens.
It is available in black, white and sand (or gold). Here are the specs translated with Google and copied from Taobao:
New HT70 17000 lumens, advanced custom settings UI, player experience
1 using four LUMINUS SST70 lamp beads
2 can choose the color temperature of the lamp bead: cool white / neutral (the lamp is SST70 P2 grade)
3 maximum brightness of 17000 lumens, up to a range of 1 500 meters
4 has a tactical mode to switch between daily use or search and rescue
5 use 2 sections / 4 sections / 6 sections / 8 sections 18650 rechargeable power lithium battery (not included)
It is recommended to use Haikelite 18650 3000mAh power lithium battery
6 one-handed, simple and fast operation
7 built-in advanced intelligent temperature control settings, can automatically adjust the brightness according to the working state of the flashlight and the outside temperature
8 compatible standard tripod interface, standard screw head
9 lock function to prevent accidental light
10 double-coated tempered anti-transparent purple optical lens, higher light transmittance
7 6 using metal aluminum reflector
7 7 aviation grade aluminum alloy military standard three-stage hard anodizing anti-wear surface treatment
This price is for one-handed battery price. Please charge battery and charger with battery and charger.
Slight touch is inevitable during the processing, perfectionism carefully shot
7 8 size: 235 (total length) * 86 (head) * 51 (barrel)
7 9 weight: 840g (bare tube)
7 0 Packing: 1340g
On the manual it is stated to use NarsilM as UI.
The price is around 230$ and the specs look really promising. You might want to get it on 11/11 because it is only half price then. I guess it will be quite expensive at the Haikelite Aliexpress store but maybe there will be a Banggood coupon later.
