Any Xeno. ES1 for low voltage only (alkaleak, NiMH), or E03 for any (add LFP and Li-ion).
Armytek Prime A1 maybe?
Eagtac D25A, but not too cheap, although it meets most of your requirements
Ultratac A1 stomps the Tool AA, any version. Best $15 you could spend. Customer Service is top notch as well. CW and NW options. The NW is very nice. It’s the only AA/14500 tail clicky light I have and use regularly. Everyone in the house has one. My 12 year old boy carries his everywhere. He’s beats the heck out of it. Looks like hell but still works perfectly.
Xeno and Eagletac are great choices as well.
the new manker
Really? The shape is practically the same.
What exactly does your opinion depend on?
And compared with the ThorFire TG06S (I own it)? Which do you think it’s the best?
Thank you :+1:
You mention ability to headstand. If the head crown is crenelated, enough light will escape when headstanding to be obvious the light is ON and, make it useful for very subdued lighting. A plain, non-crenelated head crown will mask the fact the light is on by not allowing any light to escape, making it possible that the light could be left ON accidentally.
I've lived with a ThorFire TG06S for over two years of daily EDC. Dropped a few times, wet in rain a few times. As sturdy a AA as one is likely to find at a budget price point. Very decent tint. Lens O-ring is GITD. Non-crenelated head crown. Reversible clip. UI is H>M>L. It always starts on High, which some users dislike. For a pocket utility light I personally like that it starts on H, as that is usually appropriate for my needs in the field. It also offers the added benefit of a practical low-battery warning; it begins starting on M when the battery is getting weak, then later begins starting on L when the battery is almost useless. Plenty of advance warning to find a replacement battery.
At a higher price is the Jaxman E3. Some nice emitter options. Non-crenelated head crown. Reversible clip. UI is L>M>H, so it's more of what I'd call a "Gentlemen's light", suitable for dark, populated places like reading a menu in a dim restaurant. Much thicker tube walls than most other 1AA lights. I haven't beat on this one as much as my TG06S but, it's worked perfectly.
+1 on the value of the Ultratac A1 mentioned above. Smaller, shorter & lighter than either the TG06S or the E3. Otherwise very similar.
Last is Acebeam M10. Smaller diameter than the A1 but a little longer. UI is L>M>H. Non-reversible clip, non-crenelated head crown. It's my "Gentlemen's light". Carried often but, not beat on or wet. Available in different anodized colors.
slmjim
TG06S gets my vote.
Sofirn SF14 2.0 is a good light.
Manker E03H, has head switch, almost the same, and then you get tail magnet instead. Very useful. Includes headband. See BLF and Youtube review link at bottom of this site Think I would go for the Nichia version.
A possibility is the DQG Slim 1/2AA with extension tube. Will take nimh, Alkaleaks, and 14500. I’d avoid submersion but it doesn’t mind rain.
The most compact tail clicky AA size I could find.
Thank you everyone for the suggestions. I like the flashlights that you guys listed and am currently working towards acquiring some of them.
Those Xeno flashlights look great.
Could you please list the reasons why Ultratac A1 stomps the Tool AA? I do not doubt what you said, I am just curious.
This is very good information, I appreciate it.
Have Tool AA. But my general use AA
is a Jetbeam Jet-1 MK x 3 now.
Bought them on ticket for around $16USD,
apart from first one when they came out.
Tried probably a dozen others.
NONE touch it. max output around 450 lum
But it holds that till battery gone.
450-600. Not really anything to talk about in actual light.
It’s just a very Niice torch. To hold and use.
Quality. You won’t fault. Build. One of the better ones.
At any price.
I want more output?. Usually a S41 or C8+
Do it properly.
I loooove the Jet-I except that the beam’s horribly green. Almost as bad as my Quarks.
Just my two cents.
I had a TG06S and gave it away. It worked fine but felt clunky both in feel and use.
Have a Tool AAA which should be similar to the AA and it got beat up accidentally right after I got it, and even though I took the whole thing apart and cleaned it and tested it, still doesn’t turn on like %25 percent of clicks.
Better tint, no blinkies. I believe the TG06S starts in high doesn’t it? Yes, it does. I have one too, well, not really, the wife took it. Starts on high is a no no for me. A mighty fine light though. I don’t mind the Tool, I just prefer the A1. I also like Ultratacs customer service. I haven’t had a problem but have contacted them about other things in the past. Fast and helpful. Haven’t had that same experience with Lumintop when actually having a problem with a product. I honestly don’t think you can go wrong with either the Tool or the A1. The A1 in NW just does it for me.
Ahhhhh, love the Jet-I as well. My favorite twisty. Your right, stock emitter is blah. Easy fix though.
I’m just lazy…
Well, to be fair, I didn’t want to chance ruining a perfectly good light.
It’d kick ass with a ’351 in there, though.
Yes! the Jetbeam Jet 1 is hands down my most reliable AA light plus it seems to run any AA/14500 I put in.
I bought a Jetbeam 14500 battery from BatteryJunction and I think it fried both Jetbeam e10r and a Utorch UT01, but not the Jet1MK.
