I have a crappy little headlamp/magnifier that uses 2 5mm leds. Years ago I changed the leds to Yuji 3200k hi cri and they were great! Just not quite enough output. The driver??? A single 22 ohm resistor and 3xAAA driving it. I added in parallel a 47 ohm resistor to up the driver current by about 25%. Much better now!
Old eyes suck! Just about to the point that I canât or shouldnât work with tiny SMD stuff.
Phosphor slip on attachment for my CuTi 1600mW 450nm pocket laser made from some stuff I had laying around.
Not the best tint or output, around 54lm but does convert the laser to a flashlight. Can serve as a dust cap too.
This probably would too with a better lens. In my experience turbo is also sometimes overpowering for as short as it lasts so that rosiness is lost in reality. Your pupils are so constricted from DEM LUMENS
Wow that FW1A is so green. I wonder if it is because Lumintop switched to the FB4 tint bin or is it because the reflector raises the DUV that much compared to TIR optics.
Occasional shit post necessary when times are slow.
âModdedâ two Spyderco knives (Southard & Smock) which never got carried due to their clips to deep carry Ti clips. They will both see a lot of pocket time starting today!
Tested a hole range of emitters in a C8 and decided aside from a white flat you really cant beat a domed XML2 U4 with a 4.2A driver, just a lovely clean tidy spot with nice spill
that said there is still one or two emitters left to try⌠SST40 & 2mm White flat
Thatâs where a magnifying glass and some glasses become necessary. My short distance vision started to suck a couple years ago, but various strengths of reading glasses and some âhelping handsâ kept me in the modding game.
I gave my LT1 permanent aux leds. I first was tempted to go red or orange, preventing melatonin suppression you know when using the LT1 as night light . But I wanted the aux leds so dim that any physiological effect is ruled out anyway, so I decided on pretty 485nm leds, which at this very low current looks to be about 500nm (out of the range of melatonin suppression after all )
I picked up batt-minus at the ground ring near the USB-socket, soldered an oldschool through-hole 39 kOhm resistor in a via, and then soldered the white wire to that resistor (covered the solder joint with some kapton tape).
I scratched the soldermask off 4 bits of the led+ trace and thus created solder pads for the plus-side of the aux leds. The minus sides of the aux leds were interconnected with a thin wire. The end of that wire was soldered on a pad scratched into a trace that connects to some thermal pads of the 2700K main leds (they are electrically connected to nothing so can be used freely), just to have a solid place to go to. Another pad scratched in that same trace was used to solder the white wire to.
39 kOhm is a very high resistor so the aux leds are really really dim, only well visible when it is pitch-black. The first picture is an impression of the colour, the second picture is about how dim it really is, look at it in the dark to get the idea. The switch leds are at low setting btw.
The aux leds should drain the batteries in about 35 years.
