What is it?
Timeâs up, no winners this time
Phosphor slip on attachment for my CuTi 1600mW 450nm pocket laser made from some stuff I had laying around.
Not the best tint or output, around 54lm but does convert the laser to a flashlight. Can serve as a dust cap too.
Nice cap and idea
Does the stuff melt if illuminated for too long?
Itâs a silicone compound.
Much better tint than the SST-20? But the stock SST-20 achieves slightly negative duv at turbo.
This probably would too with a better lens. In my experience turbo is also sometimes overpowering for as short as it lasts so that rosiness is lost in reality. Your pupils are so constricted from DEM LUMENS
Edit: I just looked at my old pre-mod numbers and mine was not below bbl at any level: Lumintop FW1A discussion and review - #350 by contactcr
Wow that FW1A is so green. I wonder if it is because Lumintop switched to the FB4 tint bin or is it because the reflector raises the DUV that much compared to TIR optics.
Occasional shit post necessary when times are slow.
âModdedâ two Spyderco knives (Southard & Smock) which never got carried due to their clips to deep carry Ti clips. They will both see a lot of pocket time starting today!
Tested a hole range of emitters in a C8 and decided aside from a white flat you really cant beat a domed XML2 U4 with a 4.2A driver, just a lovely clean tidy spot with nice spill
that said there is still one or two emitters left to try⌠SST40 & 2mm White flat
White flat 1 into D1S yesterday
Moonlight mode @6ft to wall
âŚYes, my Tool assisted.
After the C8 driver, I decided to implant a warm XP-L HD into the Jet-II MK. Now itâs nearly perfect.
Took it from a BLF A6, which is now completely empty. But well, never used it anyway.
Modded my i3 some days ago
Put a screw-in clip and it works just fine!
I had to do another hole besides the existing one because otherwise the 2nd screw wouldnât be possible to use.
Currently it has a 15mm driver with Crescendo + reverse clicky switch + a XPL-HD CW Led on a 16mm Copper DTP MCPCB!
They have a few other designs too search for southard
Thatâs where a magnifying glass and some glasses become necessary. My short distance vision started to suck a couple years ago, but various strengths of reading glasses and some âhelping handsâ kept me in the modding game.
And Lots of Light â- Can never have too much light with Old Eyes
I gave my LT1 permanent aux leds. I first was tempted to go red or orange, preventing melatonin suppression you know when using the LT1 as night light . But I wanted the aux leds so dim that any physiological effect is ruled out anyway, so I decided on pretty 485nm leds, which at this very low current looks to be about 500nm (out of the range of melatonin suppression after all )
I picked up batt-minus at the ground ring near the USB-socket, soldered an oldschool through-hole 39 kOhm resistor in a via, and then soldered the white wire to that resistor (covered the solder joint with some kapton tape).
I scratched the soldermask off 4 bits of the led+ trace and thus created solder pads for the plus-side of the aux leds. The minus sides of the aux leds were interconnected with a thin wire. The end of that wire was soldered on a pad scratched into a trace that connects to some thermal pads of the 2700K main leds (they are electrically connected to nothing so can be used freely), just to have a solid place to go to. Another pad scratched in that same trace was used to solder the white wire to.
39 kOhm is a very high resistor so the aux leds are really really dim, only well visible when it is pitch-black. The first picture is an impression of the colour, the second picture is about how dim it really is, look at it in the dark to get the idea. The switch leds are at low setting btw.
The aux leds should drain the batteries in about 35 years.
Nice idea â I like it! No trits needed. :+1:
A BLF friend of mine did an emitter swap for me. The Thrunite TH-20 is a great light, simple head lamp for a really good price. Excellent quality. Only the stock emitter is a bit too green/yellow. Had a 219B 9050 sw30 installed. Now itâs wonderfully warm. Direct comparison to a cool white emitter makes it look so incandescent.
So itâs not as bright as it was before, but itâs only a marginal drop. This kind of headlamp is meant for near-field tasks anyway. Headband is very comfortable. Iâm going to be using this for a lot of night time work around the home & car.
