TK's Emisar D18 review -- 3x18650 photon grenade
275 posts / 0 new
Lexel
Lexel's picture
Last seen: 6 hours 14 min ago
Tally-ho wrote:
Lexel wrote:
Aux board successfully tested
Its seems that there is a little mistake on this protrotype with the AUX LEDs colors order on the external ring. It looks better like on the inner ring when yellow is placed between green and red. Pretty sure you already noticed it but worth mentionning to be sure.
its warm white not yellow, camera does not show it right
SKV89
Last seen: 1 hour 40 min ago
SKV89 wrote:
I measured my XP-L HI 4000k at 10,600 lumens at 1s with my TA lumen sphere calibrated with Maukka lights using VTC5D fresh off the charger. A bit disappointed with the output since the 7-emitter E07 makes 7,000 lumens at 1s, but the tint is very nice. The top of ramp is set the same as turbo so double click from off takes it directly to turbo. Typical Anduril lights sets the top of ramp at about 50% or so of turbo.
Does anyone else have the XP-L Hi version? I’m curious is the XP-L HI version dimmer than the SST-20 version. My M43 with XP-L HI 5D was 1,000 lumens lower than the XP-G2 5D version.
EDIT: I just realize one of the batteries was a Sofirn 2200mah and not the VTC5D. I remeasured using 3x VTC5D and got 12,400 lumens at 1s. Better but still less than what I expected.
I just took a tint measurement at turbo and got this:
CCT: 4137K
DUV: -0.0024
CRI (Ra): 73.1
R9: -18.5
Rf: 70
Rg: 97
Ra: 73.1
5D is still one of my favorite tint. Looks very perfect neutral white at night time with no hint of yellow when my eyes are adjusted to the 2700K-3000K house lights.
contactcr
Last seen: 6 hours 10 min ago
What did you end up getting for measuring tint/CRI?
SKV89
Sekonic C-800
Turby3Pots
Turby3Pots's picture
Last seen: 5 days 20 hours ago
Does anyone know what the sustainable output is on this light?
Starting @ 14k lumens for the 5000k, what will it drop to but hold? 5k lumens?
contactcr
~2,000 probably based on the charts in the OP
Sunnysunsun
Sunnysunsun's picture
Last seen: 3 hours 28 min ago
Photos don’t attach for some reason.
https://imgur.com/4dDAeEL
Got a aux LED board from Lexel and got it to work after 6 hours of struggling.
contactcr
You don’t want to let anyone know what you learned?
JasonWW
JasonWW's picture
Last seen: 4 hours 45 min ago
Here you go.
Sunnysunsun
I was tired last night and just wanted to share my results.
The + goes to I+ on the driver, the – goes to G. I tried to bridge R4 but I believe it may be possible to solder the + directly to the furthest pad of R4 (from I+) and have it work.
The steps for replicating my mod are:
Buy driver from Lexel
1. Disassemble the front of head- remove optics, desolder the big red/black wires connected to the mpcb that poke through the middle hole from the driver
2. Remove reverse polarity protection ring by prying and then unscrew the driver.
3. Solder wires to the lighted board/your aux led. Solder those wires through the hole in the mpcb shelf and to the board in the aforementioned positions. Leave a couple inches of wire. (Too much and you’ll have to cram the wires in later, too little and they’ll be too short)
Test everything!
4. Pull the two original thick cables through the mpcb hole. I did this buy soldering a thin wire to the tips of both thick wires to help me pull them through. I can draw a diagram if someone wants it (send me a pm).
Test everything!
5. Reassemble everything.
psmbfuer
Last seen: 2 weeks 5 days ago
Subscribed
JasonWW
JasonWW's picture
There is an easy way to subscribe without making a post. Just look at the bottom of post #1. There is a button you can click.
Chatika vas Paus
Last seen: 2 hours 23 min ago
I want to update Anduril on my D18. This red ring that covers the screws is glued or what?
ToyKeeper
ToyKeeper's picture
Last seen: 1 hour 25 min ago
Yeah, it’s glued. I pried mine off with the back end of a nail so I could remove the retaining screws and the driver.
It’s also pretty inconvenient to take out the optics and unsolder the MCPCB wires before reflashing, so I almost never do it. I hope if there’s ever an updated version, it’ll have convenient reflashing access.
DB Custom
DB Custom's picture
Last seen: 4 days 14 hours ago
My buddy says he is going to gift me his D18, the one I swapped in LH351D’s, so I will have the entire Intl-Outdoor collection. He says it can sit over here gathering dust as easily as at his place. Lol
Who knows, I might actually put it to use!
ToyKeeper
ToyKeeper's picture
Lately my favorite way to use soup-can flooders is to remove the optics so it runs in mule mode, then ceiling-bounce it for photo fill lighting. I only run it at ~6000 lumens for a few seconds per shot, but it sure is handy having so much omnidirectional light to eliminate the shadows.
Here are a couple shots taken that way, at night, with a single flashlight as the only light source. I just grabbed a couple random items to use for test shots:
hcanning
Last seen: 2 weeks 2 days ago
Just wondering how many people have measured the lumens of their D18s, perhaps with SSTs?
In my quasi-calibrated sphere I get 15-18k lumens depending on the cells I use (brand new VTC6 and 30Q or older VTC6) with mine which has 5000k SST-20s.
The VTC6 are clearly more powerful but just wondering if it’s likely this light is putting out slightly more than the claimed 14k.
Absolutely in love with this light. Insane output in a lovely compact form factor and terrific build quality.
contactcr
No 18k lumens is not realistic. I think quasi calibrated answers your question, lol
hcanning
What about 15-16k?
I say ‘quasi’ because it’s accurate with cool white lights, but I had to apply a different correction factor for neutral/warm white based on lights that I already have, so it shouldn’t be wildly inaccurate.
contactcr
Maybe with VTC6 at 0s. It’s the worst way to try to guess calibration. You should use a regulated mode but I don’t have that LED in mine.
DB Custom
DB Custom's picture
But again, is it fair to calibrate a light box with a small 300 lumen light and expect the box to be accurate in testing a 15-30,000 lumen monster? Radically different output between the calibration lights and real world lights.
My light box tested quite close when looking at the calibration light or similar small output lights, but correcting it to exactly match the calibration light costs several thousand lumens when testing a 23,000 lumen beast. Fair? Accurate? Who really knows… if I knew where to take Ham’r to test it on an actual sphere I’d do it and find out where reality is… but what company that owns a very expensive sphere is willing to test my creation? And so assumptions are made by necessity…
contactcr
18k lumens would have to be pulling close to 60 Amps which is how I came to my answer. I don’t think 6 SST20 are going to pull 20A from a VTC6.
DB Custom
DB Custom's picture
I have 17 emitters in my Ham’r build, based on a Q8 body. I’ve tested quite a few single cells powering the 17 emitters and have seen current draws well above 20A from a single 18650, even up to 28A. I didn’t have a VTC6 to test but a VTC5A pulled 26.2A. This was all 17 emitters though, don’t know what it would do with 6 SST-20’s.
I don’t know about this particular light and I don’t have one here to test but may soon. This one of my buddies down H-town way came with SST-20’s and I do believe I tested it before I swapped emitters, now if I can find that paperwork…
iamlucky13
Last seen: 2 hours 1 min ago
Floodier or throwier lights than you calibrated with, and perhaps even wider or narrower apparent sources (eg – multi-emitter) are known to affect measurements.
Also, dedicated light meters should be pretty linear, but I’ve seen data from tests of smart phone ambient meters showing they are usually far from linear.
bexamous
Last seen: 1 hour 16 min ago
By chance anyone know of any comparisons of D18 with XPL-HI vs SST20?
DB Custom
DB Custom's picture
bexamous, I will be getting a D18 tomorrow and have 18 XP-L HI standing by, so I’ll know more tomorrow afternoon as to how the D18 performs with that emitter. Wink
DB Custom
DB Custom's picture
I got the pretty little golden D18 from my buddy today, charged up some older 30Q cells and took a reading as it stood, which is with the LH351D emitters I had swapped in and sliced. Then I got busy removing the Samsung’s in favor of Cree XP-L HI emitters. Went pretty well, replacing the TIR’s is something like playing Operation without the buzzer but an hour and 10 minutes after starting I have a D18 wtih XP-L HI emitters. Cells are almost charged back up, about to take a reading…
It would only show 8290 on the older 30Q’s with LH351D’s sliced… now with the same cells and the XP-L HI’s I’m seeing 10,360 at start and dropping quickly to 9600 then dropping more slowly to 9200. Seems weird that the HI’s aren’t making more than that. Beam hot spot is better, tint is more blue-white of course.
DB Custom
DB Custom's picture
An update, I have been trying to figure out if I could get this D18 to do more, but it seems the issue is a sheer current draw problem. The XP-L HI emitters are drawing a whopping 43.9A at the tail of the cells according to my clamp meter, this using Samsung 25S cells fresh off the charger and watching turn on figures. Output is 11,430 lumens but of course it falls quickly from the start numbers. My light meter is now diffused such that the meter readings are actual with no multiplier, doing this put me a few percentage points under the calibration lights but oh well, it’s easy. Silly
So the XP-L HI D18 is a 165 watt Tiny Monster! It’s pretty astonishing really, even if not making the numbers I was looking for.
Agro
Agro's picture
Last seen: 2 min 5 sec ago
I’m surprised to see that XP-L HI got more output than sliced LH351D.
icpart
Last seen: 4 hours 29 min ago
Hi,
I thinking to buy something powerful soda can flashlight but my concern is to have mounting screw. Also I like it to have 3P battery holder if I want to save little weight to power light only from one battery.
The idea is to make some holder for my bike. For now I used similar idea to hold my SP36 on handlebar with pipe clamps but it is little bulky. From all photos here I can’t see if there is under the flashlight head any screw for that?
Another candidate for me is Fireflies Rot 66 Gen2 but I read it have problem with build quality.
