Previous post updated. I tried the pencil eraser idea and while it was better than a stock nubbin’ setup, the o-ring really is the trick. What’s needed is pressure to be applied close to the perimeter of the diaphragm switch. This effectively reduces the lever arm/mechanical advantage of the switch, thereby increasing activation pressure. Also, since it’s rubber and not hard plastic, the actuation is also quieter. I’m going to suggest Neal makes these available in his store, or better yet, included in the spare parts bag.
Take a close look at the pic…driver retainer ring at the bottom, so the head was bored to .900” (to which saves the retainer ring and bezel threads) and the aluminum pill .899” the copper pill was something I had laying around, the aluminum was counter sunk and the back of the pill was stepped and then pressed into the aluminum pill, the whole package push fits into the head and the glass o-ring and bezel press everything together. The original heat sink wouldn’t make contact with the back of the FW3A driver….just a different way of and easier for me of doing it as compared to the original design…. you’ll see when you strip yours…
Woah. I had a few orings available. I dunno exactly how I feel. That is much - much stiffer. I think I would want something a touch softer. That said, I’m going to run this mod in an edc FW3A and see how it goes. Maybe a thin rubber piece in the middle to soften it up. Definitely no accidental activation though! Thanks for the cool tip!
Small update. I added a couple layers of glow sticker punched to 3/16” for a thin shim. This softens the feel just a touch. Now it’s firm and is unlikely to activate accidentally but not too firm. Love it. I think I can edc this now much more comfortably without lockout.
I’ve ran it both ways and also prefer it with a center spacer, though the difference for me is minimal. I’ve been pocketing this light nearly everyday since I’ve made this mod and seriously can’t remember any incidents of accidental activation. I’d be surprised if your experience is any different.
I’d gotten used to doing lockouts on my FW3A. It’s pretty easy to do… but sometimes I forget. I decided to give your o-ring swap-in a try, as I have a mini o-ring kit that has a 3/16” ID sized one. I hadn’t taken out the nubbin before… so small. So easy to lose. Mine was in pretty tightly though. Anyway, I substituted the o-ring and wow, what a difference. The button is really tight now. Can’t activate from angled press. The only downside is that the click sound is like 3 times as loud now. It’ll take some time to get used to it. But the implicit safeguard for stopping accidental activation seems worth it. :+1:
EDIT: OK, I went for a day with the 3/16th ID o-ring and decided it was too firm. I stepped down to a 5/32nd o-ring. NOW, we’re talking. This is better. Still tight enough to prevent accidental activation, but requires less pressure & it’s about 30% quieter than with the 3/16th ID.
I’m glad others are finding this helpful! For me, if it weren’t for figuring out a solution to the accidental activation, I would have gave up carrying the fw3a as my edc.
It should be noted that I have very large hands and strong fingers. I often don’t keep that in consideration. The 3/16” o-ring w/o a center spacer is “stiff” in my book. For others, it may be unbearably so. Both of you have built upon the concept and adapted it to your taste, so good work to y’all as well. I’m happy there is a tune-able and simple solution to a problem that can be a deal breaker to an otherwise great design.
As for the noise level of the switch, I’ve had very mixed - almost random - results during experimentation. The smallest tweak sometimes will take it from nearly silent to very loud.
I have an interesting anecdote. When I did the oring mod to my early aluminum FW3A, it was super stiff and I needed to add a spacer to soften the feel. When I did the same mod to my FW3T, it made the switch a bit stiffer and more consistent, but definitely not super stiff at all. Not as edc secure (ie prevention of accidental activation) but much better than stock.
Made modifications to anduril firmware source and now I find the light much more edc friendly:
Removed strobes.
Removed ramp blips.
Disabled FET, so it should be regulatet at 2.8A now.
Faster ramping speed.
I am adding link to compiled firmware file (based on latest Anduril from TK firmware repository with my little modifications) if someone is interested. You will probably need to make modifications to ramp setup - lowest level "1" (one click) and highest level "90" (one click). And tweak some other settings.
If it works for me, doesnt mean it will work for you, so no liability or warranty. Use at your own risk and have fun.
