I completed the mod, took about 20 minutes? Would have been quicker but I added a twist, not really sure if/how much of a difference this makes. I put aluminum foil over the center diffuser post. Figure whatever light might have gotten absorbed there is now reflected. Hard to say if its any brighter or not, but it can’t hurt. The foil extends from the base to about 1/4” of the top, just cause that’s how my cut ended up. It would be interesting to compare this LT1 with another now.
Ha, I asked about this exact mod being part of a potential future production run or if it will be a one-off thing. Though looking at how the lantern functions, it’s probably only a few lumens different.
Just a small warning: the protective tabs on the bottom of the 18650 cells shipped from Sofirn can leave glue after them. Noticed that when I popped them into a charger and one of the cells didn’t charge correctly until I cleaned the bottom connection properly.
Even with an angled reflector I describe in this post, the lumen output change was barely noticeable at the lower levels. Not noticeable enough to make me think posting pictures was worthwhile.
Just a heads up, mine was ordered on 10/12 , shipped via speedpak. So far speedpak with USPS sucks.went from DC to NJ , then to Indiana and next Kentucky. I am in Ohio . The updates for tracking happen seemingly the next day after it moves. It’s finally in Ohio. Should have it today or tomorrow. Again thanks for the team that made this.
I just had a chance to try out my first LT1. It will be a gift, so I didn’t really do a complete run-down. But it seems to work fine, and the candle flicker mode looks realistic. I didn’t find any manufacturing defects. It’s a very nice light. I left positive feedback for Sofirn in eBay, as they requested.
After charging I found the USB port flap had come off. I am not rough with my lights. I have 3 Wubens that I have used more than the LT1 and never had a problem. I have a Nitecore several years old that has never had a problem. Not to mention a couple of phones with port flaps that have been used for 5 years or more and have the original flaps. Anyhow I thought I would mention it. I’ve sent a PM to Sofirn and to Barry. Here’s a photo.
I thought the USB port flap coming out was a definite possibility when I got my LT. Hopefully Sofirn will make them available for sale when they inevitability get lost.
The round stem that goes through the hole of the head body snapped. It appears to have broken off where I expect there is/was a larger ball or whatever, that is on the inside of the head to retain the opened flap. I simply pulled the little tab to open the flap and folded up to insert the USB plug and it came off in my fingers. Totally unexpected because, as mentioned, I have had good luck/experiences with port cover flaps on other lights and devices.
I hope they can at least send me a few, not just one and that it is not too difficult to insert.
I took a look inside my LT1, the rubber piece has a long . . .
nah, this needs a picture.
It looks like a replacement would feed through the body and one could grab the piece before the retention piece has to squeeze through the body. Likely a little isopropyl alcohol would help with the job also.
It looks like it broke right where the widened portion is. With length like that it should be easy enough to pull through. Thanks for the photo
I was about to forward this light to a relative in CA, but they are definitely not going to be able to install a new one themselves. So I’ll delay the sending I guess.
I lost mine 2nd time out. It’s my hope they’ll offer The switch cover as well, just from experience I know I’ll need a few and possibly an o-ring or two. Oh and if ever offered I’d buy an extra shade or two.
I Do Like this lamp though. Other than these somewhat minor details the thing is built like a tank and runs for days.
