Good to hear that you have good expectations for your business. Looking forward to the new site and maybe some nice new l4p developments
But, but
I’m glad to hear that your business is doing well. I look forward to supporting you in the new year. I’ll try and help you offset those extra costs some
Well, this business model is created for start-ups,workshops, etc. and it works ok, there is much less paperwork compared to real limited liability company, so I'm not complaining.
Before that model, there was basically nothing that would be good for "start from scratch" companies, rules and amount of paperwork are the same regardless of your income and size of your company, 10 000€ or 100 milion € income - same rules.
Anyway,plan is to have new LLC for bigger customers/orders, and leave this smaller company/workshop for small orders.
You had me worried but I’m relieved to se the page is only temporally down because the business is running well
Despite the new bureaucratic obligations I think congatiolations is in order!
I wanted to make an order, saw everything out of stock, just read the last posts of this thread. good to hear its just temporary and everything is going well !
Congratulations, I think.
I would like a little help here.. I ordered the MOSX2 4xP-C MCPCB awhile ago (with leds) and ended up ruining it by drilling out the mounting holes too much and shorting the traces to the base. I ordered another one after that and re-flowed the components to the new board but still can't get it to work properly. Below is a picture explaining the problem.
Basically if I solder the led pads onto the board it shorts out some of the traces. I checked the traces to the aluminum base and there is no continuity there so I don't think I've done what I did last time.
You need to use those small FR-4 pad boards on those pads first, without them it's very hard to solder wires because this board is large and sucks heat from soldering iron too quickly:
Without those pad boards, actual + and - pads are these:
Pads in green are just there for mechanical purpose, to make soldering pad boards easier, you can see vias on pad boards only connect actual + and - pads to upper copper layer.
Note: "- pad" here means pad which connects wire to mosfet Source pins, not LED - (cathode).
Thanks for the reply.
A few things.
- Those pads you circled in green don’t do anything for the function of the board, they are just an anchor point for the larger pads soldered on and I should be able to solder the wires directly to the “actual pads” you marked. Correct?
- When I apply voltage to the “actual pads” the leds do not light up. Switching polarity makes no difference. However if I apply voltage to the “actual pad ” to the smaller pad just above or the the top negative pad the leds light up. I desoldered all the components except the bridge and I get the same result. Should this be happening?
If everything is working as intended, should I be able to just apply voltage to the correct pads and the leds should light up, or must it go through the driver first with the other three wires connected? I have been testing with a bench power supply and not using the driver.
I hope this is clear enough.
It’s because the FET is closed. That’s why he keeps using the term in quotes and says that it is not the same as LED -
If you bypass FET with your test leads you can get it to light up (as you found out) but under normal conditions it needs to have the driver control the FET if you are going to use the “normal” pads identified in the picture. It sounds like it is working as intended.
Great. I’m still a bit stumped on how to hook this up to the driver. I’ve got the LD-B4. I haven’t seen a picture yet of how this would be wired to the board. There are two holes, I think these go the led pads, but where do the blue, red, and white wire go on the connector? I see an M and a G on the driver, I assume these are connected to the MCPCB. Does someone have a picture or explanation?
Datasheet explaining the driver connections (see last page):
Here is explanation of how JST connector wires are coded and MCPCB layout:
Thanks, I didn't realize there was a datasheet. However, I can't get it to light up.
Any ideas to why it isn't working? There is no direct short when I hook up the power supply, just an open circuit.
I did not have a good enough look to know why it does not light up but you do need better solder/more flux/a hotter solder iron
and heater under pcb
This board is easy to solder because of those FR-4 pad boards, easier than average standard DTP board, there is no need to pre-heat MCPCB.
Everything looks connected correctly, soldering is a little bit messy, you should try to clean boards and check for shorts, only 3 wires are mandatory for work: thick red and black wires, and thin red (GATE) wire, please check with multimeter if there is connection between pads on driver and pads on MCPCB for those connections, especially gate signal (try to check that connection by placing one multimeter probe directly on mosfet gate pin,which is the most right one if you look from board center).
Ok, I got everything soldered back together, in the process I managed to crush the temp sensor and burn the wire connector so I just soldered them on instead Cleaned the boards up, and the light turns on. I just can’t figure out the UI though, it seems really complicated, and the light doesn’t seem to be following the instructions on the PDF…
Moon seems to be the only mode that works.
Ok never mind that last post. I did in fact ruin the NTC temp sensor unfortunately and melted the connector bit a little, but I got it working, finally! I stupidly had the moon and the gate wires mixed up.
I recognize things after a lot of effort just not working, ruining stuff and doing that sort of mixups. Used to do that all the time and it still happens. Glad you got it working!
