Yep later altogether will all those new boards
[Clemence]
[Clemence]
Hi Clemence, are you still planning on making this board?
If the E21a works nicely with a Carclo triple I might try putting it in the FW3A.
Ryzbor:Any chance of sending a 2*3500K (d220) + 2*4500K (d220) = 4000K mix to Maukka? For replcing the green 4000K D240.
Osram has a desktop program that can take the individual measurements and calculate the resulting mix.
Osram ColorCalculator. Free too
Better late than never: thanks, I’ve played a bit with it but it’s very complicated however it helped me figuring out some stuff.
@Clemence, any chance of restocking the d220 4000K in the newest future?
what triple optic is good for an E21A / Optosolis ?.
possible?.
these any good?;
https://www.cutter.com.au/product-category/led-optics/carclo-optics/carclo-tor-optics/page/2/
thanks.
bump. anyone?.
so cant an E21A / Optisolis be in a triple ? 10507?.
possible?.
these any good?;https://www.cutter.com.au/product-category/led-optics/carclo-optics/carclo-tor-optics/page/2/
thanks.
Hi Clemence, what can you tell us about the 219F and 319B leds, apart from that no high CRI versions are listed?
I will send some 3000K and 5000K (both D340 R70) to you and hopefully you can forward few fresh 219Fs to Koeff. They have been sitting in my box for almost a month. Have no time to test them.
[Clemence]
bump. anyone?.
so cant an E21A / Optisolis be in a triple ? 10507?. optosolis:what triple optic is good for an E21A / Optosolis ?.
possible?.
thanks.
I don’t know. I don’t have any triple board yet to tell. Maybe you can find it online somewhere
[Clemence]
djozz:Hi Clemence, what can you tell us about the 219F and 319B leds, apart from that no high CRI versions are listed?
[Clemence]
I can do a led test sure
Koef has not been seen on BLF for 4 months, I will send some leds to him but he may not be into testing them at the moment?
clemence: djozz:Hi Clemence, what can you tell us about the 219F and 319B leds, apart from that no high CRI versions are listed?
[Clemence]
No problem, no need to send him if that’s the case. Let’s pop them Jos
[Clemence]
I have an AT WIZARD PRO 6500k E21A from Clemence. Great Light!.
I am considering swapping for a more 5600k Daylight white.
would I be right in saying it would mean a LED mix of say maybe 6500k 5000k?.
possible ?.
worth it?.
kind thanks.
would I be right in saying it would mean a LED mix of say maybe 6500k 5000k?.possible ?.
worth it?.kind thanks.
Better get another Wizard and put 5700K quadtrix E21A in it. Everytime you open the press fit bezel it will damage the bore.
[Clemence]
To those placing order approximately last week, please be patient. Last week I broke my pinky toe. It was hard for me to moving around since I had to keep it slightly level with my heart all the time. Otherwise it will bleed and creates pain. I’m much better now and should be able to work normally in one or two days.
[Clemence]
Take good care of yourself, Clemence
Pinky toe comes first, then your customers, sounds a healthy attitude . Get well soon!
Check these new boards test result:
Thanks Johnkey, I borrow your pic here… [image] The copper board works unexpectedly way better than predicted. From many tests performed in BLF, we knew the tighter the LED pitch the hotter it gets. Not only because the copper trace surface area needed to shed the heat from the LED base reduced, but also due to the “photon cross talk” as mentioned by Nichia in their application notes. The LED takes and recycle the photon from the neighboring LEDs and the stored photon, instead escaping as ligh…
[Clemence]
Pinky toe comes first, then your customers, sounds a healthy attitude :+1: . Get well soon!
Thanks Djozz =)
10pcs E17A sample ready to pack for Finland
[Clemence]
Look at these super long leads. Jeez. Making maukka’s job too easy IMO
Does anyone need NVSL219B-V1 SW45K [4500K ANSI BBL] 9080 ?
I have 10 of them laying around in germany.
