The best flashlight is the one that you always have with you. ;-) I fully agree with you except for one thing. I have some doubts that SBT90.2 is an emitter that fits well into a pocket- / EDC- flashlight. I see following challenges here but please feel free to correct me:
Price/Size ratio:
Usually, EDC lights have a quite sensitive pricing level. With a $ 35.00 LED inside the price is likely to reach "premium" areas.
Size/Heat ratio:
SBT90.2 is a monster in terms of excess heat, being driven up to more than 20A. The smaller the flashlight gets, the more difficult it will be to transfer and dissipate the large amounts of heat. Unless driven at lower currents with more efficiency, maybe other LEDs would suit better?
LED/Reflector Size ratio:
With its die size, footprint and domeless layout the SBT90.2 seems to be best for throwers. Since these specs would collide with a small sized reflector, there might be alternative, cheaper but also brandnew LEDs like SST-70 or XM-L3 more appropriate? However, maybe with the right TIR lens the lack of a large diameter-reflector could be compensated somehow.
Lux_perpetua is Haikelite?? Or it look more alike ? Nevermind…
Have anyone try put this sbt90.2 to convoy L2? Does is fit? Just for a try with convoy driver…who know it will be much so low heat? Idk.
I’m just curious how the 20+ amp passing and where the heat will dissipated. I think most about current flow should be regulated constantly with rise with temperature. Or is there any better regulator out there for sbt90.2?
Not even remotely.... He's also not working for any flashlight maker.
He's just another guy who is enthusiastic about these tiny little devices we all call `flashlights`. Call me nitpicking or whatever but mostly I've got something to rant about a new model. Sometimes it's the UI, sometimes the chosen emitter, more often it's the thermal regulation and sometimes it's just details in the design that I cannot fully agree upon. With so many great minds here on BLF I started to ask myself the very question if we could put our minds together, develop some nice concepts and see if we can encourage one or more manufacturers to follow our ideas. Rest assured, some flashlight manufacturers will surely have a look onto BLF's "think tank" even without being actively involved. :-)
It still doesn’t make sense. You can do a 9V LED with 3S but not a 12V and if you are going to use buck for anything less than 9V why would you choose 3S? You need 4S for 12V out
Sorry, I think we misunderstand each other completely right now. I never meant to talk about a 12V LED. Instead I was talking about a 3V LED that requires a buckdriver to convert the voltage of 12V (3x 21700 in series) down to the 3V LED voltage. I hope it makes sense now. Sorry for the confusion.
If that’s the case (which seems pretty slim chance of happening) you should do 3s2p 18650 and make a long tube where you can choose to put 2, 4, or 6 batteries in and scrap the idea of charging.
Even better since we are dreaming make a buck-boost driver and have either two tubes or an extension tube so people can do 3p or 3s2p or anything in between!
Wow first time I’ve heard of this new light. I was going to say I prefer a more compact 3x18650 since 3x21700 is about the same diameter as 4x18650. I also like the SP70 and L6 form factor. Maybe even a 32650 battery host would be one of a kind. I would love to have a long base ball bat like flashlight for self defense.
Realistically all true, but I don't really care - it's for me, not the general public . My problem would be fitting the 20 mm MCPCB in a small head, and getting the reflector hole to fit around this huge LED. There are XHP70 tactical lights around, little bigger maybe than pocket carry, but similar argument could be made against those but they do tend to have boost drivers that limits the amps considerably, least considerably from what we typically do with a FET driven XHP70.
I'd probably go with a larger pocket carry light like the Lumintop SD26 - takes a 26650, has a great small SMO throw reflector, etc. Vinh used to rave bout this light and for good reason. I got one all modded up runnning NarsilM - outstanding quality and performance. Shame it's apparently dropped now - great light, should have done better and been rev'd up. The craze of TIR optic multi-LED lights kind of killed it. Here's the page on it: http://www.lumintop.com/sd26.html, broken links to buy one.
I've been working on the SBT90.2 in a 1504 pill and a B158 pill. Got the MCPCB fitted in both, with clearance for 22 AWG wires.
The brass 1504 pill was designed for a 16 mm MCPCB so had to dremel out a shelf or lip to widen it out - took a lot of hand work, least for me, but think I got a fairly even surface now, widen to about 19.4 mm or so. Still need to sand down the MCPCB to fit, and it does, barely. The 22 mm wires are a tight fit right now - think'n of widening out the LED wire holes even further. Clearances between the solder pads and the brass pill wall is really close - would be risky/difficult to get 20 AWG wires in there. The plastic retainer/centering piece can't be used anymore - the threads have been completely eliminated for it, so will have to drill and tap out holes for 2 screws to hold the MCPCB down. Other option would be thermal grease/thermal epoxy combo - something I've done before, but think the screws is a better approach and I've done a lot of those too.
For drivers, right now plan on using an existing SIR800DP 17 mm, 4 mode driver I already have in the 1504. For the B158, the B158 pill I modded with the SBT90.2 takes an odd size driver of ~18 mm, so need to adapt a 20 mm to fit.
These things never go easy and haven't had much time lately to give it the hours needed.
I like the concept, for me, I categorize this kind of light as “What was that noise outside” sorta light. It would sit at home or maybe go on a camping or fishing trip. A little too much size to be carrying around for extended periods, although the mass helps with the heat. I’m fine with a single cell, medium size reflector, side switch light. My wish list appears to have been answered with the Astrolux FT03 SBT90.2 that’s coming out. I just cancelled my Nightwatch NI40 because of the ongoing issues with the clicky/mode switching. The reflector of the Astrolux is about the size limit I would carry around in my pockets. (Cargo shorts) The 26650 size body calls to me because I really liked the feel/grip size of a C cell Maglight.
No no,haikelite is making almostly the same as Lux_perpetua showed us, 85mm head, 3*21700 batterry, type-c, fast charging and Andùril UI, pic below is raw material what the new light will be made from.
That all sounds real good, bout perfect actually, and HL tends to overuse alum in their lights which is a good thing for this LED. Just hope the finning is aggressive and the pill area beefed up.
HL host is super robust and good heat shedding with their fins. Looking forward to this especially considering it will have USB-C recharge instead of a proprietary charger.
Should blow away the FT03 in beefiness, runtime, throw. No comparison really - look'n forward to more details. I got an original MT07 engraved with my BLF name, from doing the original review. Now has a sliced XHP70.2, custom driver - it's a beast! This new SBT-90.2 sounds like it will be a very similar form factor - bout same head diameter, 4x18650 vs. 3x21700, etc.
