Burn in and quick calibration check. So far working very well.
First, make sure my inexpensive DMM is ok:
Next, a quick check of the RD6006.
I’ll do some more checks tomorrow.
if you want to reshape the case, you need a hammer to hit the curved place gently, the case material is soft. and waiting for your test, you can contact me if you have any questions when using it, and I cannot see the picture because I cannot access the picture link :person_facepalming:
very good work, you can continue to test, if there is any problem, please let me know
Load check and burn-in. All good so far. I like the user interface. It is easy to use. I set 3.3, 4.1 and 5V into memory 3,4 and 5.
I am going to let it run at low power for several hours. The fans don’t run at low power settings so the supply is silent.
Do you have plans for more new products to fit the 160x74mm cut out?
I could use a better bench DMM. Mine is 3,999 count. I’d like 60,000 or better at a reasonable price.
sorry, for this size, we have no plan now
haha , you can continue to test
This is a very interesting design. I am mostly interested in Constant Current mode and would like to know how fast does the circuit switches from Constant Voltage to Constant Current. In other words, what surge current must I expect on the output if I connect a sensitive circuit to it. Are there large capacitors directly connected to the output?
Thank you
Thank you
Our output capacitor is two 330uF in parallel, our switching frequency is about 70kHz, so your sensitive circuit should absorb at least ΔU*C energy.
customer review
RD6006 USB WiFi DC - DC Voltage current Step-down Power Supply
[excellent product!!! very well packaged(well packaged for rude delivery, we both don't want to see a broken device, it is a waste of time and money)]
https://www.aliexpress.com/item/4000282551930.html
This is a very interesting item.
I’m mainly interested in the graphical monitoring of voltage and current like other more famous DMMs.
Very interesting software for PC …
Can you expect a version with 3.5 “or 4.2” LCD display ?
(I hope he will arrive soon)
and any improvement in voltage and current monitoring?
It works very well both in the laboratory and in the assembly line.
now I am testing one in my laboratory and 4 in assembly line …
Next day I post some other information about my experience with RD6006-W
RS6K
Any news and specification about higher current version? I have biffy 1KVA transformer and like it made some PSU with that new RD6006. Can you tell me if that the higher current version will have the measure resolution like 1mA in RD6006?
Very professional looking power supply! If i have enough funds, i might order one.
Looks nice and I plan to buy one, probably with different PS and box, but I don’t see anywhere on pictures the female green connector for input voltage: is it included with RD6006? or box? Do I need to buy it separately and if yes could you please provide its reference?
Also, as I plan to use a spare laptop PS which delivers about 21VDC, my understanding is that RD6006 will then be able to deliver only up to 20 V: is that correct?
The input connector and a temperature sensor come with the RD6006. There is also a fan on the back of the RD6006.
A CR1220 battery is required to back up the time and date. The battery is not included with the RD6006 or the case. The supply works without a battery but doesn’t remember the date or time.
The S06A case includes a 50mm case fan and power board for the fan.
Drop is specified as >10% and > 1V. The instructions say to set the input to 62V for 60V maximum output.
I guess you will get >19V and <20V.
Thanks for this detailed answer
Very interesting software for PC …Can you expect a version with 3.5 “or 4.2” LCD display ?
It works very well both in the laboratory and in the assembly line.now I am testing one in my laboratory and 4 in assembly line …
Next day I post some other information about my experience with RD6006-WRS6K
Thank you so much for your message and your support
I am so happy that you like it
for big screen, there is not plan now , we are planing to make higher power for RD series
in fact, 2.4 inch , it is ok, for now
you can share your experience for RD6006W, If there is any problem, we can talk it here
