I see raccoon, just had to fiddle with it for it to look good in your quote. I briefly observed this while pming with sb56637, happens on the Avanced Post Editor. Will report to him looks like an easy fix: empty the vertical dimension box/variable for it to always get properly resized on par with the horizontal, keeping aspect ratio. Improving :-)) the forum.
Thatās correct raccoon* and *Barkuti, I never recommend specifying a height dimension. Just the relative width percentage is enough. (And in cases where the user forgets to specify the width, the forum style should now limit the width automatically to 100% maximum.)
Where you can still cheat is with tables, you can take comfort in throwing off the page alignment for everybody by manually specifying a super-wide table. :innocent:
You never dared to try some nasty figure, raccoon city? :-D I once did a 600+% here, the thread turned out really nasty looking I swear. It could have served as a shenanigan by a troll, forcing moderator intervention.
All that remains now is to unify the forum post editor. I am used to syntax reconstructing quotes made with the Simple Post Editor, it's a hardship which goes both ways (Advanced to Simple too). People wouldn't flee, at most they'd complain for a few days while re-learning and getting used to the new editor, wonderful time for a lot of jokes.
The new change appears to override inline styles for images now, unless I add a ā!importantā flag. That flag is generally not meant to be used that way though, so Iām not sure how best to add images which arenāt maximum width.
Usually I just post images via a macro or script which generates the relevant markup, so extra markup isnāt much of an issue for new postsā¦ the new change definitely reformatted some of my older posts though.
Looking into the siteās stylesheets, I see that thereās a style like this:
img {
max-width: 100% !important;
height: auto !important;
Does it still work without the !important bit? Thatās what makes it override regular-priority local styles.
The max-width tag never worked well with the advanced editor, it broke the aspect ratio at least as far as I know. And since the simple editor doesn't supports web addresses with special characters, I do not endorse it.
Not the first time I say this, but I'll say it once more: the post editor needs unification, in my honest opinion. Quoting posts back and forth between simple and advanced editor is often burdensome and ultimately unnecessary.
OK, letās try removing !important from max-width: in the site CSS. This will probably result in a few badly formatted posts where the poster added an unreasonable max-width, but should be a decent compromise all around. (I would recommend using just width:, not max-width: when you specify an image width. And image height should almost never be specified.)
The problem with just using āwidthā is that if the image is small and you choose a larger % width, it is going to expand that image making it look blurry/not sharp/pixellated/terrible, especially if youāre browsing on a larger high res monitor.
For example, on my monitor this 256x256 image gets expanded up to 983x983 pixels when I choose width of 75%. On the other hand, max-width helps avoid that expansion beyond the imageās native resolution. Anyway, it looks like youāve fixed it, so thank you.
Yep. But that's how it is, there's nothing wrong with it. Look at this dude I often use, it is one of these gifs of yesteryear, many of them are pretty cool and I must admit I even miss lots of 'em which still may be hosted in some old web sites. When images or gifs are so small resolution-wise, if we aim to increase their size it is best to work it out mentally/manually with some small fixed multiplier (2x, 3x, 4x maybe), or use a very small percentage as relative width.
There it is, Mr handsome coffee drinker at 4x. Rocks! :-))
One of the āproblemsā with people who doesn't wants to see pixelated stuff is that by default Android browsers do not allow to zoom in all web pages. Suffice to say I always enable the force enable zoom option, and you should too.
