Yes, its more like stucked at the lowest ramp level.
JasonWW: ver_ivanz007:I have an FT03 that won’t turn off. Even if I click the button, it stays on. It is still ramping and strobe and turbo is working. It just won’t turn off. Can you help me what is the problem on my light?
Sounds like a driver problem.
Does it stay on at a low level like 100 lumen?
Channel one (single 7135 chip I believe) might be defective and stuck fully on even though there is no signal to tell it to turn on.Yes, its more like stucked at the lowest ramp level.
Okay, this sounds different. Is it bright at all or just barely glowing? Sometimes one of the 4 dies in the xhp50.2 (and 70.2) will glow when off, but it doesn’t draw hardly any extra power and does not cause an issue.
If you have a DMM you can measure the drain when the light is off. You undo the tail cap an put your probes on the battery end and the bare battery tube. Set your meter to mA or uA and put your red probe into the socket for measuring mA or low current.
If the drain is under 0.5mA (500 uA) or so you should be okay. I don’t know what the stock drain is on this light, but this driver design and UI should be around 22-180 uA (0.022-0.180 mA).
Interested in another for my Dad cheers
ver_ivanz007: JasonWW: ver_ivanz007:I have an FT03 that won’t turn off. Even if I click the button, it stays on. It is still ramping and strobe and turbo is working. It just won’t turn off. Can you help me what is the problem on my light?
This is barely glowing. Might be the issue with some XHP50.2 that you said.
I have yet to measure the drain but I just unscrew the Tailcap for now.
Interested for one in cw, thx
Sent. [quote=RVDWB5] Interested for one in cw, thx [/quote]
Interested for one, thanks
Sent. [quote=Orbit] Interested for one, thanks [/quote]
I’m interested in a green one. Code please.
Hi - I’d like a blue one. Code please.
Still available.
Order placed. Thank you Freeme!
Is it possible to buy a version of ASTROLUX FT03 XHP50.2 in green anodizing? Interested in. .
Code for xhp50 please.
There is a thread on that.
[♛ FreemeGB] ASTROLUX FT03 in BLUE & GREEN - ALIVE!
Considering buying a FT03 today. Please pm the coupon code.
With a dedomed sst-40 it’s about 350kcd+
I am in, thx
Im interested. Coupon please
Interested for one xhp50.2, thanks
