While your GT pictures were valuable to show the beam was not diminished too much, they were not directly addressing the issue being discussed which was how much the scattered light from the beam diminishes the users eyesight.
Regarding the best light for dirt: if the dirt is, for example, very red, a light with less red in it might scatter a bit less.
The great thing about Hank’s lights is that the emitters are offered in a wide variety of color temperatures, so most anybody can get one that fits their preference!
For Raleigh scattering to have any effect the particles involved would have to be no bigger than 40nm, but typical fog droplets are in the 10-15um range, so Raleigh scattering is not relevant and Mie scattering is. Atmospheric dust, however, ranges from about 1nm to 30um, so both Raleigh scattering and Mie scattering are valid models, though the Mie scattering will be a greater contributor.
That said, your eyes are your best tool to evaluate how a particular flashlight works for you. :sunglasses:
I wish you could offer the old style switch cover. The white, semi-translucent ones just aren’t as elegant in my opinion, we all remember them from the cheapest flashlights. Old D1/D1S had it right.
I think this is pretty valid, and that those are very useful beamshots. Your comparison with the GTs (which IIRC are even regulated drivers) shows a marked difference, and leaves two possible explanations that I can think of: the CW XHP35.HI is higher binned, because CW LEDs come in higher bins, or the CW penetrates the medium (air, water vapor, and other particles included) better.
Unless someone is dealing with a very homogenous medium that reflects and/or refracts specific wavelengths more than others, your best bet is probably to just get the LED with the highest surface brightness you can find.
People need to pick the LED they want. If you like neutral throwers better, that’s fine. If you think you see your target better with neutral or warm light on it, that’s fine. If you want a high CRI thrower, that’s fine too. Color rendition has value, and that value is different to different users and use cases. And the best part is Hank will install anything he reasonably can just because he’s that awesome.
I get why some of the discussion wasn’t interested in those particular beamshots Dale, as there’s a lot of discussion about the visible, through-air beam (the lightsaber!) being “worse” with CW lights. Though from the looks of it, that just got debunked as well.
As for my $0.02, there’s nothing quite like my Z1’s pencil-beam stretching across a local reservoir and getting to see that cool white lightsabre-effect visible out to hundreds of meters.
I am glad that the forum finally using my beamshots
It is hard to make same conditions through a year And I can’t repeat all flashlight photos one day. Mostly because it is a lot work but otherwise a lot of them borrowed or rebuilt since or sold.
But now I see it is worth the effort to have that collection. I am also late with photos but Soon I will add a lot of lights to the tables.
The K1 is designed for a 21700; it will probably work with an 18650, but may need a rare earth magnet or two stuck on the end to make it long enough for reliable contact with the springs.
It would be ideal, if Hank’s listening if the springs were long enough for the K1 to be flexible about battery types, but Emisars have typically used short, stiff springs intended for low resistance. Long springs with wire/braid bypasses solve both problems, but that’s an extra production step, and Hanks lights usually hit pretty competitive price points.
Thanks for the info. I just bought 50E flat top for my Fireflies E07 … not sure if that will work with this or not but I guess I’ll see once this bad boy is ready for sale!!
Yes, a 50E should be a good cell for the Noctigon K1. It only needs to provide about 5 Amps, so a high-capacity cell makes more sense here than a high-amp cell. Using something designed for high current will only make the driver’s regulation hardware run hotter, which may actually cause it to regulate to a lower level than a more moderate cell.
A high-amp cell might make sense for the 12V boost version, to keep the maximum output going as long as possible… but it’s probably not a good idea with the 3V linear version. That’ll just give it more extra voltage to burn off.
You can easily get adapters/holders for 18650s to make them fit in 21700 devices as well. Many ecig/vape shops likely even have some for sale now that many devices are moving to the larger cells.
