I donāt think the pictures are exposed right. The catapult doesnāt have nearly this much spill and same for fo3 if thatās the sst40 version. SBT90 seems to throw better than ft03 though as the objects in the hot spot appear brighter. Also looks like a slightly wider hot spot, which I suspected, and thatās a hood thing usually. This abt90 spill is what I am actually worried about. If the pics are in fact overexposed, the spill may not actually be that bright.
I own both the catapult and the ft03 both versions
Received my cells yesterday. They measured at 4,242mah and 4,166mah
In a MF01 Mini with SST-20 4000K, Golisi 4300mah cell got 3,860 lumens at turn on compared to 3,770 with the Vapcell/Shockli 26650 5500mah which measures about 6,000mah. Iām pretty sure the SST-20 4000k was already pushed to the max. I hope to see a bigger difference with the NI40 SBT90.2. Still waiting for mine.
I tested both my Golisi Gold 4300 and Vapcell 5500 on my MF01 mini. Both pulls in 23 to 24 Amps on the tailcap on Turbo. Iāll try again with a much thicker wire.
All these beamshots are nice but has anyone actually measured throw and lumens output on a specified cell at a specified voltage? Seems strange Bluzie got one to take pics of but no measurements? I'm in the 2nd batch I guess, waiting for it to be shipped.
Here are some comments from TLF by the user who posted this video (LightintheNight). Iām kinda confused now cause according to Nagonka the 40T was 32% brighter than the Shockli.
I do not know if this works like this ā¦. but I tried with very simple means to display the first 4 minutes of the control with temperature measurement. Safe far away from professional and only for good eyes, but just handy
Edit: a few more comments ā¦
- Use found a full Samsung 30T battery with 4 or 5 charging cycles, but now has a deepTop ;-(
- the lamp was running all the time on Turbo, in another attempt in high regulates them The first few minutes hardly down
- the 30T had just after the 4 minutes turbo only 3.8 V
- the 30T brings a slightly higher turbo brightness than all the 26650 batteries that I have tried before
the lamp was not quite cold to start, because I previously 26650 batteries have measured briefly, ie the whole should be extendable by 10-15 sec
Have times a few details added above, was with 30T battery ā¦
@ hjelpestikker With these batteries, I had compared the starting brightness ā¦. The difference when starting on Turbo (pure data without conversion): - Shockli 5500: 367 - Keeppower 5200: 372 - Thrunite 5000 (evidently protected): shut down - Imalent 4500 (mE protected, but left): 369 - ijoy 4200: 366 - Samsung 30T (21700): 376 (not quite full, in the video then complete even 388 ) For comparison: at high, the value was at all around the 300 Lg LitN
I hear ya! Cant wait till someone from blf gets one to do a proper reviewā¦
I personally dont have good equipment to measure (just my phone) but I will when I get mine. Iāve got a shockli and a some golisi cells coming, should be here before the light.
Iād like to stuff this led into several different size lights to find itās best home. Iām thinking its going to be something with a 3ā head or
bigger, and 3 or more cells. I have a tn32 with a bad driver, that will be first. Iāll have to get creative to make it work.
I agree. Looking forward to you and other testing it.
To the best of my knowledge and based on output,The life of a Golisi on max[increments of 5 min.] will not be much more than my buddies MT35 W/XHP 50.2. Turn on was 4100L
5 minutes-3.83V
10 minutes-3.62V
It drains the battery as to be expected. That is why I have 3 X Golisi and 4 X Aspire. :sunglasses:
I got a modded triple XHP50.2 3V light that hit over 30 amps off a fresh GOLISI, so high amps draw is fine with me. The main thing is how this light does on throw, compared to the 220 kcd rating. It's the simplest thing to measure, in fact I find it wayyy easier than doing beamshots, though results may and will vary. I got 3 light meters and they have about a 5% variance range.
This SBT90.2 sure looks like it beats the dedomed XHP50.2 and the dedomed SST40 in throw, and of course much higher in lumens. Not sure where it is head to head with a XHP35 HI in throw, but the XHP35's require a special driver because of the 12V and restricted amps.
As far as Iām aware the XHP35 HI doesnāt throw as well as the SST40 but itās pretty close. Besides having a slightly smaller head the Acebeam K75 is around 40-50% more intense than the BLF GT/Astrolux MF04. Acebeam T27 XHP35 with its 70mm head does 340kcd and the FT03 (same head size) does 367kcd with a Dedomed SST40. Obviously everyoneās measurement are a bit different but it does seem like the SST40 outthrows it by a bit and the SBT90 outthrows them both. According to that Chinese video though the SBT90 intensity was slightly less than the SST40. Even when comparing bluzies pics it seems pretty close to FT03 and a bit behind the M3XS-UT (250Kcd). Doesnāt make sense to me though. The SBT90.2 should be outthrowing the SST40. Hope that made sense. Lights are shipping soon so I guess weāll just have to wait for some proper tests.
I assume you mean the SST40 DD, not the factory SST40 with dome. Things are getting a bit strange now, since I assume the SST40 is only produced with a dome, but we can buy dedomed variants, but I have to assume the DD is done after market, not by the factory, so there's no protective film/covering over the phosphor I guess?
Not so long ago, the XHP35 HI was the best factory LED available for throw, but clearly the OSRAM's 1mm and 2mm factory domeless throwers should have everyone beat, but at a cost of low amps, low total lumens output, and having a tight pencil beam. I haven't been sure how the SST40 DD fits in, comparatively, but glad you provided that info above. Of course it can be driven hard with decent lumens output and it's large surface should have a decent width beam. The newer XPL HI V4 bin LED's should also be competitive I would think, but again, not sure where it is in direct comparisons, but with the XPL HI's, all depends how many amps you can get out of one.
tm07 dedomed his FT03 and it went from 235kcd to 367kcd. Someone else said his was 357kcd. Unfortunately they are not available without a dome. Hopefully Luminus decides to make some. Could make some really good budget throwers.
Neal lists a bunch of comparative throw #'s of the LED variants for this Nightwatch NI40 Stalker here, which is pretty useful info if it's correct, and if it is using a true FET based driver as I suspect it does, based on the power(W) numbers listed.
He said heāll receive them this week and theyāll also ship the same week. Mine hasnāt shipped yet though. Someone above said the stock is supposed to arrive on Monday which is 3 days ago. I did message him yesterday asking if Iāll receive a tracking number when itās shipped to which he said yes. Tried emailing him a few days ago. Didnāt work. I only message him on FB now. Sometimes he doesnāt reply but these last few days heās been replying pretty quickly.
