[♛ FreemeGB-NOV] Haikelite HT70 4*SST70 6500k 17000 lumens 18650 Flashlight - ALIVE!
I am surprised no one has asked these important questions.Especially #1 and #2.So I will ask them.
1. What is the UI
2. What are the Outputs of the other mode groups?
3. What type of battery carrier if any is used? 2 X 4 carrier with option of using 2/4/6 or 8 batteries?
4. Are 10Amp high drains enough[ MJ1 OR GA’S]?
Off hand the Only 3000mAh high drains I can think of is the 30Q,LG HG2 and the VTC6.
IF 10amps are enough I would prefer the 3500mAh GA’S OR MJ1.
Thanks
1. ?
2. ?
3. No carrier; one piece battery tube design. All positives face towards driver. All negatives at the springs in the tail cap.
4. 10A like GA is definitely enough. However, there is a chance it uses a FET drive, so you could get a tad more output with something like a 30Q or VTC6. But I doubt you would notice the difference with the naked eye.
From Djozz’s test the output is pulling around 7 amps per LED.
Thanks. I have 8 X GA BT Protected that have about 25 cycles and have been stored since last November…….now they can have a home!
Thanks. That seems to confirm that 10Amp GA’S are enough.
Interested!
The current going through the LED is not the same as the current going through the batteries.
There is a possibility that it is not going to fit, as protected cells are a bit longer than unprotected cells.
Interested in Code for nw grey or sandy Version ... Need a Battle to DT70
[quote=hIKARInoob]
OK. In post #15 you state that 10 amp like GA is plenty. Is that still true?
If they are too long I will have to get some FT high drains.
NW must be available before I get it. I forget what light it was. I remember they initially just had CW before they got NW.
Thanks
[quote=BaronVonEissler]
Yes 10A GA, 8 pieces for this light, is definitely ok. One thing you might want to consider is to nevertheless get 15A cells like 30Qs to future proof in case a new 8x18650 monster light you want requires more than 10A per cell. You’re not going to notice too much in terms of capacity anyway.
Unprotected button top battery preferred. Haikelite recommends Samsung 30Q grade on their site for this light.
Interesting light. Performance is amazing for the head size. Just wish it was shorter (4 cells) and a bit lighter. You can send me a coupon but I’m not sure if I’m gna buy it. Do you know how long the 11:11 GB offer will last?
[quote=freeme]
Ok,Thank you.
Four more important questions to answer.
1. What is the UI?
2. What are the other mode groups output?
3. When is Neutral white available? It is Not an option on Banggoods site.
4. Is this the Only form of step down? “Built-in advanced intelligent temperature control settings, can automatically adjust the brightness according to the working state of the flashlight and the outside temperature”.
Thanks. I am sure others would also appreciate the answers. I am just the one posing them! :smiley:
Interested. Please let me know the code…
Thanks.
The beam distance[stats] on the Mateminco MT70 PLUS[1549 Meters] and the the beam distance on the Haiklite HT70[1500M] are basically the same. Yet the Mateminco MT70 Plus appears to have a much more intense beam and lights that building up a lot more. Makes me wonder.
I`m interested !
There is no way that this thing is hitting 1.5km. My guess would be 1.3km.
Can you read Chinese?!
From what I can see I think the big building is 650 meters? Small house 300 meters? Those are the numbers I see in the middle second level diagram.
If that big building is only 650 meters, to me this looks more like 300Kcd/1095m/1200yards,if that. I am just guessing that is what those numbers are.
What are your thoughts?
