[♛ FreemeGB-NOV] Haikelite HT70 4*SST70 6500k 17000 lumens 18650 Flashlight - ALIVE!
[quote=hIKARInoob]
OK. In post #15 you state that 10 amp like GA is plenty. Is that still true?
If they are too long I will have to get some FT high drains.
NW must be available before I get it. I forget what light it was. I remember they initially just had CW before they got NW.
Thanks
[quote=BaronVonEissler]
Yes 10A GA, 8 pieces for this light, is definitely ok. One thing you might want to consider is to nevertheless get 15A cells like 30Qs to future proof in case a new 8x18650 monster light you want requires more than 10A per cell. You’re not going to notice too much in terms of capacity anyway.
Unprotected button top battery preferred. Haikelite recommends Samsung 30Q grade on their site for this light.
Interesting light. Performance is amazing for the head size. Just wish it was shorter (4 cells) and a bit lighter. You can send me a coupon but I’m not sure if I’m gna buy it. Do you know how long the 11:11 GB offer will last?
[quote=freeme]
Ok,Thank you.
Four more important questions to answer.
1. What is the UI?
2. What are the other mode groups output?
3. When is Neutral white available? It is Not an option on Banggoods site.
4. Is this the Only form of step down? “Built-in advanced intelligent temperature control settings, can automatically adjust the brightness according to the working state of the flashlight and the outside temperature”.
Thanks. I am sure others would also appreciate the answers. I am just the one posing them! :smiley:
Interested. Please let me know the code…
Thanks.
The beam distance[stats] on the Mateminco MT70 PLUS[1549 Meters] and the the beam distance on the Haiklite HT70[1500M] are basically the same. Yet the Mateminco MT70 Plus appears to have a much more intense beam and lights that building up a lot more. Makes me wonder.
I`m interested !
There is no way that this thing is hitting 1.5km. My guess would be 1.3km.
Can you read Chinese?!
From what I can see I think the big building is 650 meters? Small house 300 meters? Those are the numbers I see in the middle second level diagram.
If that big building is only 650 meters, to me this looks more like 300Kcd/1095m/1200yards,if that. I am just guessing that is what those numbers are.
What are your thoughts?
I would say a bit over rated on throw. However my location and eyes don’t need or see illuminate targets that far. It’s got plenty of output in a cone I can use with useful spill.
This light is probably not a record breaker in numbers (no throw monster, no lumen monster), but is just an amazing light that throws exceptionally well, while having a ton of lumens in the spill resulting in a very pleasant flashlight experience.
I convinced myself lol:
INTERESTED!!!
Would you agree that the big building is suppose to be 650m? If that is the case, in my opinion it is more than a bit over rated. My modded M2X is 250Kcd. It would have a more intense center beam on that building than this light.
Everything is speculation and opinion until you or any of these other guys have one in hand to measure. By what I see I would be shocked if it was more than 350Kcd/1183m/1300yards.
interested
Definitely can’t read Chinese. Lol. An 85mm head with four of these LEDs just won’t do 560kcd. Also someone in the other thread said the intensity is 90% of the X65 mini which is rated 492000. This means it should be 443000. I’ve also read that the meter he was using which is a UT383 is more sensitive to cooler light so it might be a bit less than that. I think it’ll probably be 1.35km at max. I hope I’m wrong but I just can’t see it hitting the claimed 1.5km.
I blew up and thoroughly examined the beam shots of the NI40 SBT90 G2 which I am getting and the Haiklite HT70 SST70.
The NI40 SBT90 G2[advertised at 220Kcd/938m/1025yds.] puts just as much beam intensity[not overall light] on that building which is equal to the HT70.
My final guess when someone gets and measures the HT70 is that it will be between 280Kcd[1058m/1157yds.] and 350Kcd[1183m/1300yds.]
I will not argue that this a a great price for the light.
I can definitely see it doing 350k. If it can do 400k and 12k lumens I’ll be pretty impressed.
Interested!
